530 Login incorrect on FTP to homepages
Tony_W
After many years without problems I am getting a 530 error.
It first happened a couple of days ago and then rectified itself.
It's happening again now and I can get access to change any files on my website.
Anyone else had anything similar?
[edit] just tried after typing this and got access straight away.
10 REPLIES 10
Chris
Legend
Fixes: 169
Re: 530 Login incorrect on FTP to homepages
I've just raised a problem to our networks team as I've seen a couple of similar threads recently over on the Usergroup forums and in Usenet.
Prob ID 58353
Chris
Legend
Fixes: 169
The issue has been found and should be fixed pretty soon, it was caused by part of the data centre move work.
Tony_W
Thanks Chris - I'll stop fretting now.
Tony
bobpullen
Fixes: 316
Should now be fixed. Shout up if you encounter the problem again.
nickonthehill
I am also experiencing this '530 login incorrect' problem. I have just been recently connected to plus.net.
Details i am using:
username        username@plusdsl.net (my plus net username substituted here)
password          my plus net password
ftp host              ftp.plus.net
port                    21
ftp client            wsftp le
I have raised a ticket with plus.net support but any assistance here so I could fix it sooner would be much appreciated.
Nick
jelv
Fixes: 10
Wrong username for ftp! It's the username only without the @plusdsl.net
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
nickonthehill
Just tried logging in using the username without the @plusdsl.net, and I get the same 530 login incorrect error . . .
Chris
Legend
Fixes: 169
Nick,
Unfortunately your account doesn't come with any webspace which is why you're getting the authentication errors. Take a look at our sister company Pay As You Host if you're interested in webspace.
nickonthehill
ah ok thank you for the help !
jelv
Fixes: 10
Quote from: nickonthehill
d'oh - I should have spotted that!
