problem with redirecting emails - help please!
albert
Sorry if this is so obvious that everyone groans but I've been trying to redirect my PlusNet emails to gmail because I find that webmail is slow and often doesn't load.
I went to Redirects and tried to set up a redirect for <username>@<username>.plus.com but it won't let me - it says something about it being my primary account.
What do I do?
4 REPLIES 4
Fixes: 1,495
Re: problem with redirecting emails - help please!
You can’t have a redirect for an address that has a mailbox attached.
What you can do is get gmail to collect your PN emails.
I have done this and it works fine.
albert
Thanks, Dvorak,
It seems to rather defeat the whole point of having redirects...
But I'll try what you suggest.
Al.
albert
Well, I actually seem to have sorted the problem by accident rather than design.
I had set up an alias <Albert>@<username>.plus.com
I deleted this.
Then I put <Albert>@<username>.plus.com into the 'redirect' box (on the 'redirect' tab of 'manage my mail') and redirected that (apparently defunct) address to my gmail account.
I don't know why it works but it does. And I've not had to do anything at the gmail end.
Perhaps I should patent this method.
Alb.
Fixes: 585
It works because there is now no mailbox associated with the email address. As @dvorak  said earlier , you cannot redirect if there is a mailbox for the address. An alias is just another name for the assocoated mailbox.
