log in help
steveianson
log in help
I have had my Plusnet email and the same computer for years. I have alway use an email app. I have a new computer and am trying to log into Plusnet mail via webmail. If I log in with the address xxxx it log me in as xxxx@xxxx.plus.com. I use the email address yy@xxxx.plus.com. What username do I use to log in?
3 REPLIES 3
Mav
Fixes: 510
Re: log in help
For the default email address you log in using the same login details as for the Member Centre (<username>:<password>)
If it is for a mail box you have setup you use <username+mailboxname>:<mailboxpassword>
So in your example above you enter xxxx+yy and use the password you set up for that mail box.
Hope that helps.
Forum Moderator and Customer
steveianson
Re: log in help
Many thanks for the prompt reply Mav. Just to clarify you put a + symbol between xxxx+yy, should this be a space or @.
Mav
Fixes: 510
Re: log in help
Yep, just the '+' sign.
