incredimail
- incredimail
incredimail
08-01-2015 1:41 PM
Hi ,I will be connected to Plusnet from BT on the 12/01/15 and would like to continue using INCREDIMAIL can anyone tell me how to do it ? Thank you,Dennis
Message 1 of 2
(771 Views)
1 REPLY 1
Re: incredimail
08-01-2015 8:41 PM
Have you set up a Plusnet email address in Manage My Mail http://email.plus.net/? You should be able to receive messages on that now though sending will only work from Webmail until your Plusnet connection is live.
For setting up Incredimail the incoming and outgoing server information is given at the bottom of your Member Centre Connection Settings page.
Plusnet don't provide an email setup guide specifically for Incredimail but any of the others here covers the principles.
David
David
David
Message 2 of 2
(404 Views)
