email help
- email help
email help
31-03-2010 6:49 PM
my broadband has been activated i can send emails but the people i sent them to cannot send them back to me saying the delivery failed permanently from their end
Message 1 of 6
(3,568 Views)
5 REPLIES 5
Re: email help
31-03-2010 7:01 PM
Have you set up the email address correctly in your mail client? It should be anything@username.plus.net if you have a catch-all email.
Message 2 of 6
(1,863 Views)
Re: email help
31-03-2010 7:39 PM
@paulat Are you using an email client on the computer, or Plusnet's webmail?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 6
(1,863 Views)
Re: email help
01-04-2010 7:11 PM
Quote from: dgwebb Have you set up the email address correctly in your mail client? It should be anything@username.plus.net if you have a catch-all email.
plus.com not plus.net? The setup documents say it should be username.plus.com.
My email doesn't work so I'm just looking for clues!
Message 4 of 6
(1,863 Views)
Re: email help
01-04-2010 7:30 PM
The default email address is usually firstname@username.plus.com where firstname is the first name of the account holder and username is (you guessed it) the user name for the account.
The Manage My Mail tool https://portal.plus.net/manage_my_mail shows mailboxes (including catchall if active) that are set-up for the account.
David
Message 5 of 6
(1,863 Views)
Re: email help
02-04-2010 3:14 PM
My bad, I'm with F9 so mines @username.force9.co.uk so I figured plusnet would be @username.plus.net cause it makes more sense to me
Message 6 of 6
(1,863 Views)
