attachments in webmail
daveh1956
trying to attach small word files to emails, get message saying "unable to send message", any thoughts?
4 REPLIES 4
Mav
Fixes: 515
Re: attachments in webmail
I think there is a 7MB limit to attachments in Webmail.
Forum Moderator and Customer
mrob
I'm also having problems sending emails with small word files attached....and similarly get "unable to send message" sometimes.
I discovered through trial and error if the email has more than one attachment it is less likely to send and so have had to send emails with one attachment at a time sometimes.
I assumed this was part of the general current email malfunctioning situation....but any thoughts would be appreciated.
I stress these are small word files.
MrSilver
Fixes: 9
Just tried attaching 3 empty files and it works, 4 breaks, so seems liek a limit of 3 attachments rather than size. I dont usually attach many files so not sure if it used to do more than 3?
Once good test is to try from Outlook/Mail etc as a client and see if its the mail server rejecting or a config/error on webmail itself?
Genesis1-1
Every time I bring up an attachment after responding to the upload instruction it shows in the attachments box with a no entry sign against it. When I either click on the send button at the bottom of the page or the letter box ( with the envelope projecting from it ) I get a "Failed to send" message. Does anyone have a solution to this or is there anyone who can tell me what I am doing wrong?
