Using Native Plusnet Email
BarryBoater
I have a native Plusnet email address  [email protected]
Some of my mail is failing as it does not pass required tests.
The plus.com domain does not appear to have a DMARC or SPC record
Can this be fixed.
Tags (2)
27 REPLIES 27
Fixes: 386
Re: Using Native Plusnet Email
Are you talking sent mail, and if so, where are you sending it? None of my sent messages are being returned/bounced.
Fixes: 582
Have you checked the <accountname>.plus.com ,  mine certainly has DMARC & SPF and I believe the Plusnet servers also implement DKIM
To add to that , whilst I dont normally use my <account>.plus.com email , I've just sent email from it to my externally hosted domain. The headers in the receved email show a valid SPF record was found and it contained a valid DKIM signature
BarryBoater
MisterW Yes I have checked <myaccount>.plus.com and this has no DMARC or SPF failures. I have inspected headers in my sent emails (to self)  and also sent mail to email deliverability checking site with result of DMARC and SPF failure.
Fixes: 582
Are you sending using the Plusnet mail server , relay.plus.net ?
Fixes: 386
@BarryBoater As I asked in my original post, which domains are claiming your mail is failing these checks?
BarryBoater
Yes, I am using relay.plus.net
BarryBoater
gmail.com for example
Fixes: 386
Gmail should not be rejecting emails from relay.plus.net, but I'll leave further comment to @MisterW as he has more knowledge on this than I have.
Fixes: 386
@BarryBoater A further thought - are these rejected messages sent from your home connection, and if not, have you got authentication enabled?
Fixes: 250
That was going to be my question - use of the SMTP server on network without authentication is likely to give prissy Gmail something to belly ache about.
BarryBoater
Yes, authentication enabled.
Gmail is prissy about no DMARC or SPF records which is the object of my post
Fixes: 386
@BarryBoater I think you will find that the PN mail servers are correctly configured, but if you want to argue they aren't...
Fixes: 582
@BarryBoater ok so I'm very confused as to why your emails are failing, I've just tried sending to my gmail account and it works fine, viewing the headers on gmail gives
Original message
Message ID    <[email protected]>
Created on:    20 April 2024 at 07:39 (Delivered after 3 seconds)
To:    [email protected]
Subject:    Test message
SPF:    PASS with IP 212.159.14.18 Learn more
DKIM:    'PASS' with domain plus.com Learn more
DMARC:    'PASS' Learn more
You are using the native email address in the FROM aren't you ?
BarryBoater
@MisterW Thank you, but if I send to my Gmail account using my Plusnet mailing account i don't receive the mail, so I can't check the headers!
If I test at https://mxtoolbox.com/spf.aspx using <myusername>.plus.com I get there is no record. Same if I use their DMARC test.
I guess if you were to use this test you would have records?
