Two copies of every Plusnet Email?
borlandstewart
Any ideas why I am getting two of the same emails from PlusNet every time they send 'one'?
Thanks,
Stewart
6 REPLIES 6
Fixes: 244
Re: Two copies of every Plusnet Email?
Check your account setings.  There is a default email address and a contact one.
borlandstewart
Thanks Townman... I should have mentioned I'm not great at this type of thing, so although I understand what you are saying I have no idea how to sort it.
I've watched the help video too but my settings look the same as suggested... I have a Postmaster and I have a mail@ but that looks right?
Any other suggestions? Please make it simple 😳
Fixes: 244
Take a look at this https://www.plus.net/member-centre/account/details
Service and billing emails are sent to both [email protected] and the contact email address on the above page.
borlandstewart
So do I edit that to read the postmaster@ address or remove the mail@ and replace it with nothing?
Fixes: 244
I think either will go. I have postmaster@ on mine.
borlandstewart
Many thanks for your input & solution.
Have a great 2022.
