Timeouts
- Timeouts
Timeouts
16-01-2016 2:07 PM
For a few days now my email client has been slow to receive mails, and has failed with time-outs when sending email. This is using Thunderbird (on a W7 laptop).
Today I have installed Windows LiveMail. This is now also experiencing time-outs on receiving mail.
The problem seems to be intermittent; webmail seems to working ok, as does email on my phone (WP8.1); but it's hard to say conclusively.
Is anyone else experiencing this? Is it my setup, or the servers having an issue?
Message 1 of 3
(885 Views)
2 REPLIES 2
Re: Timeouts
16-01-2016 5:04 PM
Are you using any security software and if so, have you tried temproarily disabling it to see if the problem goes away?
Message 2 of 3
(300 Views)
Re: Timeouts
21-01-2016 10:34 PM
Bob
Thanks for your response and apologies for delay getting back to you.
I understand where you're coming from, with it seeming to be impacting only email clients on my laptop and not webmail or phone; but as far as I am aware nothing had altered on the laptop. I use Norton but nothing had changed with it (other than the AV signatures); config and engine version hadn't altered when this issue started. TBH I don't like turning off protection either, even for relatively short periods.
Problem is it seems to be intermittent, so is hard to track down. About the only thing I can be sure of is that the problem is between client and server. As mentioned it is not client-specific as it has happened on Thunderbird and Live Mail clients. As yet I am not sure if it is specific to this one laptop.
I did wonder if it was POP3 specific...
As no-one else has posted I am assuming it it is just me 😞
I am monitoring it and will report back if I have any further findings.
Message 3 of 3
(300 Views)
