Tidying up My Inbox in Thunderbird.
Strat
Fixes: 565
I have my Outlook configured to leave a copy of messages on the server and remove from server after 100 days.
Is this possible in Thunderbird.
8 REPLIES 8
Fixes: 383
Re: Tidying up My Inbox in Thunderbird.
@Strat I have my TB settings to not leave on server at all (POP3), but it is possible to set the length of time they are left on there in the 'Server Settings'
Strat
Fixes: 565
Excellent, thanks very much @jab1.
I don't have Thunderbird but my daughter does and this may well sort out a problem.
Fixes: 383
@Strat How many addresses does she have/does she use anything like MailWasher?
Strat
Fixes: 565
She doesn't use anything like Mailwasher but she gets very little spam.
Her biggest problem is the amount of emails she gets as a result of her subscribing to sites...if you ask me Lips_are_sealed.
Fixes: 383
And I bet she doesn't delete them and empty deleted items very often either - you ought to see the crud I cleared off my sisters GMail over the weekend.😀
Fixes: 580
@Strat if she uses Plusnet email then I hope youve taught her how to use a different alias for each site! then when one site gets compromised, you just ditch the alias...
Strat
Fixes: 565
@MisterW she has her own domain and won't give it up for anything even after getting married Wink
Fixes: 246
But if it’s Plusnet hosted, she can still have aliases, with CATCHALL set on.
[email protected] is the same as [email protected]
If there is no explicit address (mailbox or alias) for anyoldaddress@ and catchall is on, the mail goes to the default mailbox.
If anyoldaddress@ gets abused, it can be rerouted to the cyber blackhole!
