Thunderbird outgoing email problems
- Thunderbird outgoing email problems
16-11-2010 9:08 AM
I've set up Thunderbird as per plusnet instructions and can read and (apparently) send email. However. sent email never arrives at its destination and just disappears
Sending via webmail works Ok so it looks like it's being swallowed in the webmail system as Thunderbird believes it has sent it to the mail server.
Any ideas?
Mark Enderby
Any ideas?
Mark Enderby
Message 1 of 5
(1,138 Views)
4 REPLIES 4
Re: Thunderbird outgoing email problems
16-11-2010 3:32 PM
Have you tried sending an email to yourself via Thunderbird?
Message 2 of 5
(343 Views)
16-11-2010 5:39 PM
Sounds like you might have the wrong email address in the Thunderbird configuration. It won't prevent you reading the mail correctly, since that uses the username and password and it won't stop it being sent, but it would have the wrong email address on the outgoing mail.
Message 3 of 5
(343 Views)
17-11-2010 8:58 AM
...or possibly the wrong Outgoing Server Setting
Message 4 of 5
(343 Views)
20-11-2010 11:53 AM
Also on your Account settings, make sure you have "Use secure authentication" unticked.
Message 5 of 5
(343 Views)
