Suprise Migration to Greenby
mavison
Re: Suprise Migration to Greenby
@rft wrote:
Delivered-To header has appeared in my emails over the last few days. I assume this means I've also been moved to Greenby., although I've had no confirmation from them and cannot log in to the Greenby web site.
The header does imply you have been migrated. Notifications should have been sent to your normal contact address, as registered with Plusnet - possibly postmaster@ if you have never changed it. Do you get any emails from Plusnet? eg bills?
If migrated, you should be able to logon to Greenby.com with your Plusnet accouint name and main Plusnet account password, but remember to check that the brand in the drop-down menu is set correctly ie Plusnet, Force9, etc
rft
Yes, I do get emails from Plusnet under my username and postamaster. I'll try loging in to Greenby again.
Thanks for replying.
PhilipHeyes
Seasoned Pro
Fixes: 7
This evening a : Welcome to Greenby email.
Tomorrow I shall see if I can make payment to subscribe.
