Still can not send totalise emails
AL61
Still can't send email from my totalise account.
I get a SMPT Error 550. Failed to add recipient "[email protected]"
[[email protected]] domain rejected (blacklisted by local policy)
3 REPLIES 3
AL61
Re: Still can not send totalise emails
It would appear to be that I can not send emails between totalise accounts
Kentishian
As of yesterday, I cannot send emails on totalise webmail/ Shows" SMTP Error (500):Failed to set sender "[email protected]"(<[email protected]> sender rejected (Blacklisted by local policy)). Have you resolved your issue yet and if so how please?
Fixes: 246
Sender Domain Rejected (black listed by local policy)
This issue can report as server error 550. It typically arises where a user's email address has been abused for the purposes of sending spam emails. It has nothing to do with server settings etc.
This requires intervention by staff to determine the cause of the problem and to issue advice to check your system for viruses and malware. Only after your system(s) have been affirmed to be clean can the black listing be lifted. As a precaution, you should change the password on the affected email address.
Add your details to this thread - Cannot Send Emails and send a PM to @Leanne_T
