Sent Mail not being saved
CWatters
Son is using "Mail" that comes with Win 10/11. When he sends a message it appears in the "Sent Items" folder for a few seconds then disappears. However no copy is saved in the "Sent" folder.
Do Plusnet have an upto date page that lists the manual settings to configure Mail for use with Plusnet so we can check its all configured correctly?
3 REPLIES 3
Fixes: 480
Re: Sent Mail not being saved
@CWatters
The settings are here. https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/
CWatters
Thanks. Couldn't solve the problem MS Mail so switched him to Thunderbird which works fine with same settings.
Fixes: 252
This is a known issue with WIn10 Mail - not a great email client!
Windows 10 Mail App is auto-deleting Sent emails (thewindowsclub.com)
This has nothing to do with Plusnet, nor the email settings.
