SMTP problems??
tobiz
Re: SMTP problems??
I have now sent test emails successfully from: desktop Thunderbird, Gmail mobile, K9 mobile
All using my original metronet setup on all 3 except UN: myemail->[email protected]. All these connect ultimately via my router connected to PN.
Not as yet tried to setup Thunderbird on my mobile.
All my configs are (as Plusnet help page still says for metronet, plus minor change for UN)
  • mail.metronet.co.uk, port 110, all security fields: None
  • smtp.metronet,co.uk, port 25, all security fields: None
Thanks it seems to @plusnettony
GrahamS
Re: SMTP problems??
Send from my iPhone is now working with port 25 and no security with password and revised username [email protected]
But seems very slow…
Will check outlook on pc and thunderbird next
Nike
Re: SMTP problems??
Still not able to send.
Connection security: none
Authentication method: Password, transmitted insecurely.
outgoing server: relay.plus.net on port 25
User name on outgoing server is still not @metronet.co.uk although have changed it in settings.
plusnettony
Fixes: 74
Re: SMTP problems??
Can you revert to smtp.metronet.co.uk please?
 Tony T
GrahamS
Re: SMTP problems??
Outlook is able to send e-mail via the smtp metronet server now.
In thunderbird I can now send email if the settings are port 25 no connection security ,password transmitted insecurely.
However the receive settings now needed to be changed in thunderbird to use the revised username name [email protected] as before but the server settings for pop3.metronet.co.uk seem to now require port 110 connection security NONE password transmitted insecurely!
Rickmia18
Re: SMTP problems??
I can now send email through Port 25 without any security. What was the solution?
Nike
Re: SMTP problems??
Outgoing server set to smtp.metronet.co.uk on port 587.
Able to send to an outlook and an aol address but oddly sent to three gmail addresses and only received by one.
paulmacd
Re: SMTP problems??
Can now send with port 25 (but not port 587), Connection Security=none, No authentication. [email protected].
Dmorley
Re: SMTP problems??
I’m using Apple iPhone mail client. No option to remove any password authentication. I also tried using outlook client with no password authentication using port 25 and with both types of username (full email or username). ALl in smtp server.
Nike
Re: SMTP problems??
Mystery solved, went to junk in two of the gmail address so my issue seems to be resolved.
Many thanks @plusnettony
glasg0wl0dey
Re: SMTP problems??
@plusnettony
Again thanks for resolving this problem. Are you able to share why the issue arose in the first place and what had to be done to fix it? Be a techie as you like - I am 🙂
GrahamS
Re: SMTP problems??
Indeed MANY THANKS plusnet support!
Rickmia18
Re: SMTP problems??
Many thanks for resolving the issue.
Dmorley
Re: SMTP problems??
Anyone know why I can send emails over WiFi using Apple Mail client using password security and port 25 but never using mobile data. This has been an issue now for months.
Fixes: 387
Re: SMTP problems??
@Dmorley Have you set authentication to 'on'? You cannot send from a PN email address - whatever 'brand' of email you are using  - unless this is done.
