SMTP problems??
Dmorley
Re: SMTP problems??
Correct. I can now receive emails by changing my user name to my full metronet email address. However sending using any email client is not working at all.
GrahamS
Re: SMTP problems??
Same for me.
tobiz
Re: SMTP problems??
Same for me.
glasg0wl0dey
Re: SMTP problems??
Yes, I can receive (port 110) but not send using port 25 or 587.
Rickmia18
Re: SMTP problems??
Same for me.
plusnettony
Fixes: 74
Re: SMTP problems??
I'm trying to replicate but having a few issues.
Can one of you please post your errors message for me? Thanks
 Tony T
plusnettony
Fixes: 74
Re: SMTP problems??
Scratch the above request. I think we've found something.
I hope it's a really quick fix but can't say when it will be rolled out. I'm also really sorry it's been going on for so long.
As a temporary fix, try using relay.plus.net as your outbound if you're on a PN connection.
 Tony T
paulmacd
Re: SMTP problems??
@plusnettony Yes, no problem now incoming but no combination of settings works outgoing (Metronet).
Nike
Re: SMTP problems??
Same problem as everyone else.
Now have incoming with suggested fix but still no outgoing.
relay.plus.net is and has been my outgoing server and still no outgoing mail.
plusnettony
Fixes: 74
Re: SMTP problems??
If anyone is able to re-try, please do so. Thanks
 Tony T
Dmorley
Re: SMTP problems??
Still doesn’t work for me on port 25 with password security.
plusnettony
Fixes: 74
Re: SMTP problems??
Can you try no security please
 Tony T
glasg0wl0dey
Re: SMTP problems??
Good morning. I have just successfully sent an email from my metronet.co.uk account using port 25 and no security (the original settings).
PROGRESS! 🙂
Dmorley
Re: SMTP problems??
Still didn’t work for me
plusnettony
Fixes: 74
Re: SMTP problems??
Can you confirm your  outbound setting please as well as your client?
 Tony T
