SMTP Error (535): Authentication Failed
Fixes: 254
Re: SMTP Error (535): Authentication Failed
@TonyParker that matchs @-Simon- 's experience ... and I suspect matches my theory which I have escalated.
If you have an IMAP client configured on a local device, it should all work fine.
colbee
Add me to this issue also.
Fixes: 254
@colbee
Works with a local client, fails with webmail?
john_chandler
I have the same problem - just tried to send an email. I can login to Webmail just fine, but sending emails raises the SMTP authentication error.
Edit: this is using a plus.com address.
colbee
Happens on webmail, Unable to try with a client at the moment . Same this morning.
masrjk
Just to let you know... I am unable to login onto the Plusnet portal also. I am an email customer only and I think It only allows broadband customers on that. I used to log in on the MADASAFISH portal and it seems that this is still active. However, ther is no reporting funcationality
masrjk
Same for me.
Fixes: 254
Reporting email issues
Can EVERYONE reporting "me too" issues please provide the following information...
  • Email brand - Plusnet / Force9 / Free-inline / ic24 ... etc
  • The email client being used
  • How authentication (if any) is being done with the SMTP server - email address or account name
  • Mail box type - Default or Primary
Force9 and webmail I am presently gathering diagnostics from my own tests so more Force9 and webmail posts are not necessary.
masrjk
  • Email brand - IC24
  • The email client being used - Microsoft Outlook 365 and Plusnet Webmail
  • How authentication (if any) is being done with the SMTP server - Email Address
xaviern
I get the same issue
  • The email client being used - Plusnet Webmail
Is their any update on this item?
TonyParker
I've just checked again and things are the same for me too.
  1. IC24
  2. Plusnet Webmail fails, Outlook and Android mail now send fine.
  3. I don't think that I can control authentication on Plusnet Webmail.
  4. Not relevant
Fixes: 254
In general, you can in the same way you do for any other login - use the email address or the account name ... though for ic24 IIRC email address is the required credentials ... other brands will accept either.
@plusnettony - is there any update on the ic24 issues please?
plusnettony
Fixes: 81
Raised and being investigated. From memory, a solution was found. I'm not on the office though, and no access to email to check. Nudge me tomorrow if I don't post back.
 Tony T
JOEGMITCHELL
HI
I have the same  SMTP 535 problem
my email is [Removed]
Any help would be appreciated
joe mitchell
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
Robbie69
I am and IC24 user, and I have the same (535) error occurring.
I've not been able to send emails since last week (but receive emails ok)
This started the evening prior to the outage they had on Wednesday last week (17th Sep)
I spoke with PN Customer Services (Shauna - who was brilliant, really informative and helpful)
She told me about the PN 'global' webmail outage, and that she thought the send issue was lnked to that.
It seems its not, as I have been patient, and waited, but cannot send any email (not even to my self at IC24)
Can anyone advise, as having to cut/paste/manage issue using alternate email address, but its not ideal!!
Many Thanks, Robbie
