SMTP Authentication
adam945
Fixes: 113
Re: SMTP Authentication
Really glad to hear that that's sorted @Tykebike
Feel free to give us a shout if you need any further assistance at all. Smiley
 Adam
 Plusnet Help Team - Leeds
duncanbbd
I'll add something on here, related to sending from home.  should I post this as a new topic ?
I use Thunderbird and recently I get the following message and I can't send mail:
"Sending of the message failed.
The message could not be sent because the connection to Outgoing server (SMTP) ns.01383.uk timed out. Try again."
I think there is an issue with connecting through plus.net on port 587
I can send an email immediately when connected to my phone or directly from webmail, so the server ns.01383.uk is up and running.  This is actually one of my servers so I know it is up and running 🐵
thanks Brian
p.s. on the info on one of teh posts above using Port 25 will lead to problems as its not a secure port, will need to use port 587 to send
Fixes: 147
Hi @duncanbbd
I would suggest you create your own thread as this has been marked as fixed and it is a different topic/question.
Dan.
