Plusnet emails refusing to send.
Annasdad
Re: Plusnet emails refusing to send.
Any updates
Pancho4
I received an (robot) email from Force9 support a week or so ago advising that "as your mailbox has not been accessed since April we have archived the contents of your mailbox"  This has to be a mistake as I have not stopped using the mailbox daily for more than 20 years. So I phoned up Plusnet support this morning to request that the older emails be unarchived, and spoke to a very helpful young man.
He has raised a ticket to ask for the unarchiving, but I mentioned to him this problem that I am currently experiencing with email clients and plusnet mailboxes, namely I can access webmail OK but outlook and applemail are not functioning. His comment was that this disruption was entirely due to the impending move to Greenby and nothing now would change until the transfer in October (?) was complete. Is this the real cause of our email problems at the moment?
cheers
Fixes: 392
Take what first-line support say on this with at least half a bag of salt - they are clueless.
vorlon99
the person i spoke to asked me where i had found out about the greenby move, i told her on the website, i did as it asked and it said i needed a code from plusnet. she then came back to me and said it wasnt live till november. then i asked about the email thing and was sent here. usually much better support than this time.
Fixes: 254
@vorlon99
What where in respect of the Greenby migration says you need a code please?
Are you confusing YOU moving your domain name away with the Greenby migration?
Fixes: 254
@Pancho4 wrote:
On havebeenpwned.com I am shown as 19 breeches, but none shown in MXTOOLBOX.
My problem remains that I can access the force9 mailboxes OK in webmail, so the logon credentials are valid, but using the mailbox settings in Outlook 365 (windows11) and in applemail (ipads)  I seem to be unable to logon to these mail clients to send or receive.
Earlier messages that the address was blacklisted have disappeared but outlook is now questioning/rejecting the plusnet mailbox certificate.
cheers
Been a couple of bust days, so I've not been around to field this in detail.
Which bit of the MXTOOLBOX system did you expect to report data breaches?  TTBOMK that is not something MXTOOLBOX does.
So many cases running around here - do I recall correctly that you are Force9 and that when you run the email server connection diagnostics (see the link below) you encounter a certificate revocation check failure?
If yes, then try configuring the servers WITHOUT encryption.  Whilst this is not ideal, it might help clarify the location of the issue.
You state that you cannot logon to send or receive ... but then mention blacklisted state of your email address ... to know that, you'd need to be logged on!
vorlon99
it said so when i tried to use the link to get an account (which you have to make) then it says it does not recognise the account and asks for a number from plusnet
Pancho4
Which bit of the MXTOOLBOX system did you expect to report data breaches?  TTBOMK that is not something MXTOOLBOX does.  - I used the blacklist tool in MXTOOLBOX - the blacklist message has gone away
So many cases running around here - do I recall correctly that you are Force9 and that when you run the email server connection diagnostics (see the link below) you encounter a certificate revocation check failure? - sometimes
If yes, then try configuring the servers WITHOUT encryption.  Whilst this is not ideal, it might help clarify the location of the issue. - done that - no change
You state that you cannot logon to send or receive ... but then mention blacklisted state of your email address ... to know that, you'd need to be logged on!  - I can logon fine via webmail - send and receive - so I know that the logon credentials are correct. But using outlook (paid for version) and apple mail I am unable to get in to the mailbox via the mail client
Screenshot of outlook error message attached.
cheers and thanks for your patience
Fixes: 254
That has hints of server settings - do the diagnostics deliver any more detail?
Pancho4
Here is the result of the diagnotics:-
PS C:\Users\john> curl.exe -v imaps://imap.force9.net -u redacted
Enter host password for user redacted':
* Host imap.force9.net:993 was resolved.
* IPv6: (none)
* IPv4: 91.204.208.196
* Trying 91.204.208.196:993...
* schannel: disabled automatic use of client certificate
* schannel: next InitializeSecurityContext failed: CRYPT_E_NO_REVOCATION_CHECK (0x80092012) - The revocation function was unable to check revocation for the certificate.
* closing connection #0
curl: (35) schannel: next InitializeSecurityContext failed: CRYPT_E_NO_REVOCATION_CHECK (0x80092012) - The revocation function was unable to check revocation for the certificate.
PS C:\Users\john> curl.exe -v pop3s://mail.force9.net -u redacted
Enter host password for user 'redacted:
* Host mail.force9.net:995 was resolved.
* IPv6: (none)
* Trying 91.204.208.196:995...
PS C:\Users\john> curl.exe -v smtp://relay.force9.net:587 -u redacted --ssl-reqd
Fixes: 254
What happens if you use the non-encrypted versions...
curl.exe -v imap://imap.force9.net -u redacted
curl.exe -v pop3://mail.force9.net -u redacted
Note that to run the SMTP test, you need to press enter to execute the last command.  It is on the end of your post, apparently unexecuted.
Pancho4
sorry:
* Host relay.force9.net:587 was resolved.
* IPv6: (none)
* Trying 91.204.208.196:587...
* Connected to relay.force9.net (91.204.208.196) port 587
< 220 mail.enmail.co ESMTP ready
> EHLO JAC-New-PC
< 250-mail.enmail.co
< 250-AUTH PLAIN LOGIN
< 250 STARTTLS
> STARTTLS
< 220 2.0.0 Start TLS
PS C:\Users\john>
Sorry - does this help?
Fixes: 254
It makes crystal clear that on your platform, using cURL there is an issue processing the encryption security certificates.  What is not so clear are...
  1. Is this the issue being experienced by your email application though reported as a password / login issue
  2. Will the non-encrypted versions of the cURL commands work as expected - see above
  3. If the non-encrypted cURL commands work, will email work without encryption (not ideal but an essential diagnostic step)
  4. Why you are experiencing this issue at all
Pancho4
Unencrypted
PS C:\Users\john> curl.exe -v imap://imap.force9.net -u redacted
* Host imap.force9.net:143 was resolved.
* IPv6: (none)
* Trying 91.204.208.196:143...
* Connected to imap.force9.net (91.204.208.196) port 143
< * OK IMAP4 ready
> A001 CAPABILITY
< * CAPABILITY IMAP4 IMAP4rev1 UIDPLUS AUTH=PLAIN STARTTLS
< A001 OK completed
> A002 AUTHENTICATE PLAIN
> <Redacted>
< A002 NO Login failed.
curl: (67) Login denied
PS C:\Users\john> curl.exe -v pop3://mail.force9.net -u redacted
* Host mail.force9.net:110 was resolved.
* IPv6: (none)
* Trying 91.204.208.196:110...
* Connected to mail.force9.net (91.204.208.196) port 110
< +OK POP3 ready <[email protected]>
> CAPA
< +OK Capability list follows
< TOP
< USER
< UIDL
< SASL PLAIN LOGIN
< STLS
> AUTH PLAIN
><Redacted>
< -ERR Login failed.
Enter host password for user 'redacted':
* IPv6: (none)
> EHLO JAC-New-PC
< 250 STARTTLS
> STARTTLS
PS C:\Users\john>
hope this helps!
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
Pancho4
Diagnostics - Unencrypted run, just using account name and appropriate password:
* IPv6: (none)
< * OK IMAP4 ready
> A001 CAPABILITY
< A001 OK completed
> AGphY3JlZXIyAEIwbGwwY2tzIQ==
< A002 OK LOGIN Ok.
> A003 LIST "" *
< * LIST (\HasNoChildren) "." "INBOX.Trash"
< * LIST (\HasNoChildren) "." "INBOX.Spam"
< * LIST (\HasNoChildren) "." "INBOX.Sent"
< * LIST (\HasNoChildren) "." "INBOX.Drafts"
< * LIST (\Marked \HasChildren) "." "INBOX"
< A003 OK LIST completed
* Connection #0 to host imap.force9.net left intact
* IPv6: (none)
> CAPA
< TOP
< USER
< UIDL
< SASL PLAIN LOGIN
< STLS
> AUTH PLAIN
< +OK logged in.
> LIST
< +OK POP3 clients that break here, they violate STD53.
1 1047
2 21509
3 3493
4 3492
5 21632
6 21509
7 21507
8 3494
9 21507
10 21435
11 21507
12 1047
13 21535
14 21555
15 21739
16 21888
17 21553
* Connection #0 to host mail.force9.net left intact
* IPv6: (none)
> EHLO JAC-New-PC
< 250 STARTTLS
> STARTTLS
I hope that this helps
