Plus.com now moving to Greenby
Fixes: 245
Re: Plus.com now moving to Greenby
If you want to, yes, that's your prerogative, but that in itself will not cause any mail someone sends there to arrive in your Gmail account.  If no one is sending mail there ... why do you need to do anything?
In the context of this thread, if you do not have an on-going need for the Plusnet email service, when you received your migration advice email, just use the opt out facility and the service will die sometime thereafter.
queenie7
Thanks very much for your help. I'll just  opt out of transferring to Greenby and then I won't, as you say, have any Plusnet mailboxes thereafter. Seems to be a fairly easy option.
