Plus.com now moving to Greenby
smallblueplanet
Re: Plus.com now moving to Greenby
Where will notification of this move go to?
I'm getting lots of errors - that I do not understand because I am not an email software specialist! - both on my email client and now something on webmail. This is very concerning, my three [email protected] have a lot of my incoming and outgoing emails.
Helpful info needed please.
Tags (1)
smallblueplanet
I want away from Plusnet email servers asap. As I asked before where will notification of a potential move to Greenby be sent to? I don't think I know the main account details for the [email protected] account,
plusnettony
Fixes: 73
When the time comes, we'll email the contact address on the account at the very least. Please ensure this is up to date.
 Tony T
plusnettony
Fixes: 73
We're seeing a couple of issues on the network at the moment that isn't mail related, but may be causing mail issues. This is being investigated.
 Tony T
smallblueplanet
How when I don't know the details?
All I know are the login details for the x3 email addresses that conform to the [email protected] format.
Fixes: 383
everything else seems to be working, @plusnettony
plusnettony
Fixes: 73
portal.plus.net - username is the username in the username.plus.com. You can click the forgot password option, or if the one of the three email aliases you use before the @ sign is postmaster, or the same as your username, you'll use the password you use to log into the mail. I hope that makes sense.
 Tony T
smallblueplanet
@plusnettony is portal.plus.net the same as https://www.plus.net/member-centre/login? Am I trying to sign on there? Thanks. If so it's not currently loading.
plusnettony
Fixes: 73
It is, but we have a small issue on going so it may not load, or be slow. portal.plus.net is the friendlier name for the same place
 Tony T
Fixes: 383
@smallblueplanet It is - and as I've just checked it is MIA.
smallblueplanet
I'll give it a try laters and take it from there. Smiley
redsox9
Fixes: 4
Outlook has stopped receiving messages. I am on POP3 but when I try to log into Webmail I am told "Connection to IMAP server failed."
Collateral damage (temporary I hope) from the migration to Greenby?
stuck
Fixes: 4
No, the "small issue' mentioned by @plusnettony doesn't look to be that small.  Not only are the mail servers down, the plusnet home page is down as well.
redsox9
Fixes: 4
@plusnettony
Migrations paused - network issues - totally unrelated to project.
A pause that refreshes. Outlook and Webmail receiving messages again.
plusnettony
Fixes: 73
The incidents that we've experienced today are unrelated to mail platform migrations. We did pause migrations though to try to avoid any possible complications.
 Tony T
