No emails received
Thorneyfields
No emails received
Hi
No changes this end but I’ve received no emails since Sat 09/09.  I have come the long route to plusnet (freenetname via Madasafish).
Has anything changed?
Tags (1)
13 REPLIES 13
Thorneyfields
Re: No emails received
Btw I can see that the domain is due to expire on 18/10/23. I believe that Plusnet manages this ordinarily
ClaudiaG23
Fixes: 25
Hi @Thorneyfields Nothing has changed that we're aware of. Have you tried accessing your emails via webmail to see if you can see your emails being received this way?
Have you also tried to email yourself, to see if you get an error or bounce back?
 Claudia Garner
Thorneyfields
Hi
Yes -  tried webmail. Again it stops at the same point.
Also mailed myself from my work account and nothing comes through.
ClaudiaG23
Fixes: 25
Does the email show as sent from your work account?
When you say it stops at the same point, what do you mean sorry?
 Claudia Garner
Thorneyfields
Sorry - wasn’t being v clear. Email sent ok from work; shown in Sent Items as successfully issued.
When I said web mail stopped at the same point I meant the last email received was the same as seen elsewhere (i.e. 09/09)
SammyM
Fixes: 101
Thanks for confirming that @Thorneyfields, I have looked and there is nothing sticking out on your account. I have refreshed the mailbox, can you login to the affected email account and send an email from itself to itself? Then we can see if it's both sending and receiving that is the problem etc.
 Sammy M - Sheffield Team
Thorneyfields
Hi
No change to my inbox. I’ve sent mails from webmail and tablet. Neither received.
However, I have just sent mails to my work address from both webmail and tablet. Both have been successfully received.
Additional observations:
- Webmail sends but does not save [message says “Unable to perform operation. No free disk space.”]
- I checked webmail and local mail and junk mail is being received successfully (Better if it was the other way round of course)
it looks therefore as though Inbox mail isn’t being received. V odd.
Thanks for yr help
Fixes: 1,642
That suggests the mailbox is likely full. If you click on Settings in the top right of webmail, from there you should be able to check the size of each folder then add them all up to see if combined they’re below the 250MB quota.
Thorneyfields
Hi - thanks for this. I am unable to see the size for Inbox (this appears to be a special folder which I can’t access in settings.
The balance of the folders add up to ~134mb.
Thorneyfields
Have just removed a folder of 132mb. Inbox still not populating 😕
Fixes: 1,642
Hmm, I've done some further work on your account to see if that helps.
The changes should go through in 4 hours. Hopefully you can receive emails to your inbox after then.
Thorneyfields
Hi - that’s good. Now seeing a flow of mails. Now waiting for the mails over the prior 2 weeks. Thanks for your help.
Fixes: 1,642
Glad to hear that and thanks for confirming!
Let us know if there’s anything else you need help with.
