Multiple qcopies of same email sent
Mardler
Re: Multiple qcopies of same email sent
@Champnet agreed though the poor fellow has 15 or more copies which I would have thought would be more than enough to trigger an error email to me.
I will keep y'all posted.
Fixes: 382
@Mardler I don't know what the fault was attributed to- I never asked, because I assumed that it was merely an electronic 'blip' - as described earlier, this can happen if the sending station does not receive a correct acknowledgement.
Mardler
Thanks to all for chipping in.
Mardler
Have just heard from the recipient that he has had 4 more copies.
Time for a complaint.
Fixes: 382
@Mardler I don't think a 'complaint' will get you very far - it may be a fault at the recipients end - or somewhere in-between.
Mardler
@jab1 I'm not sure.
I suspect the error is with PN. If I could see my Sent items in webmail I could try deleting the offending email but there's no such folder there apart from an old one.
This is becoming increasingly annoying so a complaint seems the only way. Trouble is I can't even find a way to raise a ticket.
PN: anyone listening?
Fixes: 382
@Mardler Why do you suspect PN?
Mardler
@jab1 because I very much doubt that the recipient's service is doing it.
Champnet
Fixes: 21
 My monies on the receiving email system not returning the correct response.
Even if you could delete the offending email that wouldn’t solve the problem….
Mardler
@Champnet agreed, your second point also makes sense.
I have raised it with the "support team" and will phone PN tomorrow if no response.
Champnet
Fixes: 21
You could politely ask the support team to kill the email as it’s stuck between the two MTAs but I’m not sure of the legal implications, good luck…..
Mardler
@Champnet  that's exactly what I plan to do.
I will also ask if someone could tell me exactly what the PN system is expecting in the recipient's service received response and what it's actually sending. At least then I can advise the other party.
Fixes: 579
@Mardler the SMTP specification for mail transfer is here https://www.rfc-editor.org/rfc/rfc5321.html
Mardler
@MisterW many thanks, could be very helpful.
Champnet
Fixes: 21
@Mardler  Have you received any emails from the sending system saying it’s unable to deliver the email but will keep on trying ?
If not Ii’s possible the problem might be between receiving system and the end users email client.
