Madasafish webmail on iphone 4s ios6
adamtemp64
I am unable to get into webmail on my iphone .
It is fine on my pc.
Anybody else getting this
18 REPLIES 18
bobpullen
Fixes: 316
Re: Madasafish webmail on iphone 4s ios6
What happens when you try and was it OK when using iOS6?
adamtemp64
It just sits on the maaf homepage on wifi on my adsl connection but over 3G in Kent it works?
Ios5 was fine
Other pages with logins worked over wifi this morning just webmail no error messages etc
arthurbikemad
I have the same problem (only on iPad not iPhone), was working fine on iPad2 and 3 but since iOS6 upgrade no longer logs in just hangs on the homepage? If you login to my account then redirect to mail it does the same thing, all the other login details for my account work fine! Does Tech have any ideas?
adamtemp64
Now this gets wierd as over wifi on non madasafish account it works fine.
I am using a netgear dgnd3300 and tried all wifi encription etc no change
arthurbikemad
I'm unable to try other accounts but I have two madasafish webmail accounts, I can not configure mail as its running on my Android mobile and only one can be used at a time, or so I was told.... Anyway it was fine on the old OS5! I've tried a few things with Safari but to no effect, what's odd is Skyfire does the same thing hangs up when you try and login....
arthurbikemad
Oh wait are you saying you can log in if your not using Madasafish ISP?  I'm here now on TalkTalk with the login problem!
arthurbikemad
iOS6 webmail login problem! Was ok on 5!
Hi all, anyone here using iPhone or iPads to login to madasafish webmail? I've been using it for ages with no problems until now I upgraded to iOS6 and it hangs on the login screen?  I've reset Safari and still the same and note that Skyfire does the same thing, also it's the same on my partners iOS6 iPad2 (mines an iPad3). Found another thread where user is running iPhone with similar problem but no fix.... Anyone have an ideas? It's fine on my Android phone and countless PCs!
Thanks for any input
Arthur
Oldjim
Resting Legend
Fixes: 63
Re: iOS6 webmail login problem! Was ok on 5!
merged with existing thread to keep everything in one place
arthurbikemad
Ah ok Mod thanks.....
Right found a browser that logs in other than Safari or Skyfire
Atomic LITE works fine on iPad...
adamtemp64
Downloaded chrome last night ti my iphone4s ios6 and connected to webmail ok on my plusnet connection but still fails via safari?
Can somone at plus look at this safari based issue please.
bobpullen
Fixes: 316
I'll have a play around when SWMBO returns home later this week (I don't have an iOS device myself) ...
adamtemp64
Thanks Bob
chrispurvey
I've tested this on my iPhone with iOS6 using Safari, I had no problem logging into webmail.
I searched Madasafish webmail in Google, then from the results chose MAAF webmail and it stated 'safari cannot verify the identity of the website' this is normally a browser issue, I clicked continue and was then able to log in with no problems whatsoever.
After this was successful, I cleared the history in my browser and was able to login again with no problems at all.
adamtemp64
Chris
But now not even over 3g will it work and cleared all in safari fine in chrome on iphone but certificate error on chrome but chose to ignore.
I am accessing via the maaf homepage and entering login details on right hand box.
