Madasafish webmail on iphone 4s ios6
- Re: Madasafish webmail on iphone 4s ios6
20-09-2012 7:14 AM
It is fine on my pc.
Anybody else getting this
20-09-2012 8:09 AM
20-09-2012 11:11 AM
Ios5 was fine
Other pages with logins worked over wifi this morning just webmail no error messages etc
23-09-2012 5:41 PM
23-09-2012 5:54 PM
I am using a netgear dgnd3300 and tried all wifi encription etc no change
23-09-2012 6:02 PM
23-09-2012 6:05 PM
iOS6 webmail login problem! Was ok on 5!
23-09-2012 6:13 PM
Thanks for any input
Arthur
Re: iOS6 webmail login problem! Was ok on 5!
23-09-2012 6:24 PM
23-09-2012 6:31 PM
Right found a browser that logs in other than Safari or Skyfire
Atomic LITE works fine on iPad...
25-09-2012 10:35 AM
Can somone at plus look at this safari based issue please.
25-09-2012 4:51 PM
25-09-2012 5:25 PM
26-09-2012 12:40 PM
I searched Madasafish webmail in Google, then from the results chose MAAF webmail and it stated 'safari cannot verify the identity of the website' this is normally a browser issue, I clicked continue and was then able to log in with no problems whatsoever.
After this was successful, I cleared the history in my browser and was able to login again with no problems at all.
27-09-2012 4:26 PM
But now not even over 3g will it work and cleared all in safari fine in chrome on iphone but certificate error on chrome but chose to ignore.
I am accessing via the maaf homepage and entering login details on right hand box.
