Login failed Madasafish Webmail
Alan2112
Hi all
I have had nothing yet regarding email migration for my Madasafish webmail, which is still very much my primary email address. Today I went in to delete some mails as I am aware of the very small folder size, and if it fills then I stop receiving them. I got a Login failed message. Does anyone know if this is a temporary problem or do I need to escalate it to Plusnet?
Thanks in advance for any advice
Alan
8 REPLIES 8
plusnettony
Fixes: 74
Re: Login failed Madasafish Webmail
You should have no issues provided you visit webmail.plus.net, enter your full email address and choose Plusnet in the drop down menu.
 Tony T
Alan2112
Hi Tony
Thanks for replying, unfortunately that is what I am doing and still getting the ‘login failed’ message. Please see image attached.
Kind regards
Alan
plusnettony
Fixes: 74
Do you normally log in like that, or would you use a domain (not everyone has one)?
Can you try with your full email address (the domain)?
 Tony T
Alan2112
Hi Tony
Yes that is what I have always done. I’m not sure what you mean by the ‘full email address’ and I am pretty sure I dont have a domain. Sorry.
plusnettony
Fixes: 74
There are two sites, one for mail and one for admin.
Can you get into
www.madasafish.com ? Click on sign in not webmail.
 Tony T
Alan2112
Hi Tony
Thank you for persisting with this. I haven’t used that page for years and I have done as you suggested to try to sign in, but unfortunately it is not recognising my saved password. I have tried a couple of times to request a password reset, but the emails to do this have not come through.
sorry that has drawn a blank too, I have attached a screenshot for what it is worth.
Best wishes again
Alan
plusnettony
Fixes: 74
Thanks for getting back to us. I hate to advise this but I'm limited in what I can do here. I'd therefore be tempted to give our support team a call, we'll then reset the password for you.
 Tony T
Alan2112
Thank you for your efforts Tony. It gave the support team a bit of head scratching but it is now sorted.
Thanks again
Alan
