IP in SORBS List
Aldabbagha
IP in SORBS List
I have joined PlusNet in hope that having business line with a static IP address would resolve my issue. I run a private email server with a other services and the IP that I was given is on the SORBS spam/hacked/NoServers and Spamvertised.. I have attached the image. Can something be done?
22 REPLIES 22
Fixes: 396
Re: IP in SORBS List
This was discussed some while ago in this thread https://community.plus.net/t5/Email/Plusnet-IP-addresses-listed-in-SORBS-blacklist/td-p/1678684
The solution is to use relay.plus.net as a Smart host to send mail.
Aldabbagha
We use a email filter for spam with our exchange server. Not sure I can get the smarthost to work..
Fixes: 396
@Aldabbagha  I'm not an Exchange expert by any means but a quick serach revealed this https://docs.microsoft.com/en-us/exchange/mail-flow/connectors/outbound-smart-host-routing?view=exch... which appears to explain how to configure an exchange server to use a smart host.
BTW the standard Plusnet help documentation is a little out of date in that relay.plus.net does support TLS encryption now.
Aldabbagha
Thanks for the link but I do know how to create smarthost for Exchange, but we use mail filter for our email
So it is like this: incoming mail --> mail filter --->  Exchange Server ---> clients
Fixes: 396
I thought SORBS only affected outgoing mail.
Aldabbagha
That is correct the email filter is also used for incoming and outgoing emails
Fixes: 396
So if the outgoing filter is an external service, isn't that effectively acting as a smart host anyway ?
Ahh , but is it that service that doesn't like your IP being on the Sorbs list ...
Aldabbagha
The filter is not external, it is internal as well.
Fixes: 396
So I guess you need to configure the outgoing mail filter to use relay.plus.net as a smart host and can't ?
Aldabbagha
That is correct, however, it does offer smarthost but there is option to enter any authentication.
Aldabbagha
That is correct, however, it does offer smarthost but there is no option to enter any authentication.
Fixes: 396
You shouldn't need to authenticate. If the mail filter is internal then it will be sending from your static ip and so relay.plus.net won't require any authentication
Aldabbagha
Oh I see, shall I use port 587 or 465?
Fixes: 396
587
