IMAP: IDLE and authentication
- IMAP: IDLE and authentication
05-09-2015 2:23 PM
- I gather that IDLE is supported for 'push' notification. That seems to be working but there's a delay of some three minutes or so. Is this normal? When I tried IDLE with a mail server on my own test rig the notifications were immediate.
- I came across a thread in here that seemed to be saying that the authentication requires identification in the form of a full email address, i.e. mailbox@username.plus.com and that supplying just the mailbox+username won't work (or only partly works). I only spotted that after using the mailbox+username form, and it appears to work just fine. Is this perhaps superseded advice or something?
Thanks.
Re: IMAP: IDLE and authentication
05-09-2015 4:04 PM
Since your client works there's no need to change.
I'm not familiar with use of IDLE so I'll pass on that.
05-09-2015 5:37 PM
09-09-2015 10:27 AM
Quote from: Boxersoft I gather that IDLE is supported for 'push' notification.
Yes.
[quote author="Plusnet's IMAP servers"]~$ telnet imap.plus.net 143
Trying 212.159.8.86...
Connected to imap.plus.net.
Escape character is '^]'.
* OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA IDLE ACL ACL2=UNION] Courier-IMAP ready. Copyright 1998-2011 Double Precision, Inc. See COPYING for distribution information.
09-09-2015 10:34 AM
09-09-2015 11:14 AM
Quote Without FAM or Gamin, and IMAP_ENHANCEDIDLE set, the Courier IMAP server will manually check for changes to the folder's contents every 60 seconds, in IDLE mode (instead of in real time).
It doesn't look like enhanced idle mode is enabled for a start:
Quote ~$ telnet imap.plus.net 143
. login [-REDACTED-]
. OK LOGIN Ok.
. select INBOX
* FLAGS (\Draft \Answered \Flagged \Deleted \Seen \Recent)
* OK [PERMANENTFLAGS (\* \Draft \Answered \Flagged \Deleted \Seen)] Limited
* 8 EXISTS
* 0 RECENT
* OK [UIDVALIDITY 1395238770] Ok
* OK [MYRIGHTS "acdilrsw"] ACL
. OK [READ-WRITE] Ok
. IDLE
+ entering idle mode
10-09-2015 1:15 PM
What I'm typically seeing is 180+ seconds, not 60.
Quote It doesn't look like enhanced idle mode is enabled for a start:
No likelihood of getting it enabled, I suppose?
30-09-2015 3:46 PM
Quote from: Boxersoft No likelihood of getting it enabled, I suppose?
I should have anticipated this question I guess
I'll look into what can be done (ref: 460444).
30-09-2015 10:58 PM
