How do I setup Greenby webmail
- Re: How do I setup Greenby webmail
yesterday
On my Plusnet webmail it tells me to move to Greenby webmail.
How do I get Greenby webmail set up on my android tablet?
yesterday
The link is : https://webmail.greenby.com/
You might find it far more convenient to set up an Android email app.
yesterday
It keeps saying Login failed.
I'm definitely using the same password as Plusnet webmail.
yesterday - last edited yesterday
The first box requires an email address that exists in your Greenby Portal : www.greenby.com
that is not an Alias and not <account>+<name>
yesterday
@steveg To check what @PhilipHeyes has said you log into the Greenby portal using your Plusnet Account username and password, not any email addresses.
13 hours ago
You can open Greenby webmail in your Android tablet is browser and sign in with your existing Plusnet email address and password then follow the on-screen instructions to complete the setup.
10 hours ago
Confusion Here
email address
or
username
Are two different things so wrong one will fail ??????
10 hours ago - last edited 10 hours ago
It's email address to log into the Greenby webmail site: Greenby :: Welcome to Greenby
and
It's Plusnet username to log into your account at the Greenby portal: Greenby
Yes, wrong one will fail. Password is the same for both, your Plusnet account password.
6 hours ago
Yes, That works.
I was misled by the message on the Plusnet webmail login. that falsely states “Your existing login details will work unchanged”
