How do I setup Greenby webmail
- Re: How do I setup Greenby webmail
yesterday
On my Plusnet webmail it tells me to move to Greenby webmail.
How do I get Greenby webmail set up on my android tablet?
yesterday
The link is : https://webmail.greenby.com/
You might find it far more convenient to set up an Android email app.
yesterday
It keeps saying Login failed.
I'm definitely using the same password as Plusnet webmail.
yesterday - last edited yesterday
The first box requires an email address that exists in your Greenby Portal : www.greenby.com
that is not an Alias and not <account>+<name>
yesterday
@steveg To check what @PhilipHeyes has said you log into the Greenby portal using your Plusnet Account username and password, not any email addresses.
5 hours ago
You can open Greenby webmail in your Android tablet is browser and sign in with your existing Plusnet email address and password then follow the on-screen instructions to complete the setup.
2 hours ago
Confusion Here
email address
or
username
Are two different things so wrong one will fail ??????
an hour ago - last edited an hour ago
It's email address to log into the Greenby webmail site: Greenby :: Welcome to Greenby
and
It's Plusnet username to log into your account at the Greenby portal: Greenby
Yes, wrong one will fail. Password is the same for both, your Plusnet account password.
