Help! Emails I'm trying to send to Gmail accounts are bouncing!
Fixes: 526
Re: Help! Emails I'm trying to send to Gmail accounts are bouncing!
@accole do you actually have an SPF record ?
accole
No I don't have SPF records set up... was wondering if I needed them though
Fixes: 526
@accole it is recommended to have one
You can't create one directly on a Plusnet hosted domain, but if you read this thread https://community.plus.net/t5/Email/How-to-set-spf-DNS-record/m-p/1690951
It gives a workaround to create a standard one on your domain
accole
Thanks. Hopefully that will do the job - thanks Smiley
garywood84
I'm still having this problem, with mail to Gmail being bounced back, too. In fact, it seems to be getting worse. Recently, returned messages have this additional text, which I think could be telling:
Reporting-MTA: dns; avasout-peh-004 [212.159.14.20]
Received-From-MTA: dns; inmx-peh-001.plus.net [84.93.238.82]
Arrival-Date: Wed, 21 Sep 2022 08:48:16 +0100
Final-recipient: rfc822; [address]@gmail.com
Diagnostic-Code: smtp; 550-5.7.1 [212.159.14.20] Messages missing a valid messageId header are not
Last-attempt-Date: Wed, 21 Sep 2022 08:48:17 +0100
Have escalated back to Plusnet support.
Hobo
Having the same problem all emails to Gmail addresses are bouncing and getting this message
This is an automatically generated Delivery Status Notification.
Delivery to the following recipients failed permanently:
 * xxxxxxx@gmail.com
Reason: A message that you sent to the following recipient could not be delivered due to a permanent error. ** The remote server ?? responded with: ** xxxxxxx@gmail.com ??:?? This message was created automatically by mail delivery software on the server .
Fixes: 1,639
Hi @Hobo,
Could you private message me the full unredacted bounceback and email headers?
I'll raise to NetOps to investigate for you.
C-P
Have been having the same issue for almost 2 months now. Weirdly, only on mobile client - not on desktop, even though the server settings are the same.
 * xxxxxxx@gmail.com
Fixes: 1,639
Is your mobile client on a device that's connected to the same broadband connection as the desktop or using mobile data?
C-P
Same broadband. Broadband or mobile data has no effect. Bouncing regardless.
Fixes: 1,639
Have you tried to send the same email content on a mobile device which works on a desktop?
C-P
Yes. Always works on desktop - never on mobile.
adamwalker
Fixes: 223
Hi there, it might be an issue with the mail app on your phone, have you tried sending via webmail.plus.net from your phone just to see if the same thing happens?
Adam
 Adam Walker
martinrb
This is what I get when I try and send an email to a gmail account
(1)
Reporting-MTA: dns; avasout-peh-002 [84.93.238.88]
Received-From-MTA: dns; DESKTOPABI28RD [176.154.18.12]
Arrival-Date: Fri, 30 Sep 2022 10:55:52 +0100
Final-recipient: rfc822; jeremy.guillemot1664@gmail.com
Diagnostic-Code: smtp; 550-5.7.1 [212.159.14.18] Messages missing a valid messageId header are not
Last-attempt-Date: Fri, 30 Sep 2022 10:55:53 +0100
(2)
Received: from DESKTOPABI28RD ([176.154.18.12])
by smtp with ESMTPA
id eCkIoQRBbkc4VeCkJoUn2j; Fri, 30 Sep 2022 10:55:52 +0100
X-Clacks-Overhead: "GNU Terry Pratchett"
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.4 cv=bslfuWWi c=1 sm=1 tr=0 ts=6336bd28
a=p8cHDZ0jkx99g2qHiisrNg==:117 a=p8cHDZ0jkx99g2qHiisrNg==:17
a=HpEJnUlJZJkA:10 a=r77TgQKjGQsHNAKrUKIA:9 a=4-TN_WCqaeVPqo9tEGUA:9
a=wPNLvfGTeEIA:10 a=uBuekfuGO3PopXbFH2sA:9 a=EdhuuRbONiQy6cQI:21
a=_W_S_7VecoQA:10 a=SouxwJzPgW3XYj6zhwYA:9 a=fMZ_E1CIlfQA:10 a=S92bho3TTZoA:10
X-AUTH: martinrb@freenetname.co.uk:2520
To: <jeremy.guillemot1664@gmail.com>
Subject: Directions
Date: Fri, 30 Sep 2022 11:55:50 +0200
MIME-Version: 1.0
Content-Type: multipart/mixed;
boundary="----=_NextPart_000_0000_01D8D4C3.969CA870"
X-Mailer: Microsoft Office Outlook, Build 11.0.5510
Thread-Index: AdjUstHeio1mUkbWTKiaEi5EYl9J7w==
X-MimeOLE: Produced By Microsoft MimeOLE
X-Antivirus: Avast (VPS 220930-0, 30/9/2022), Outbound message
X-Antivirus-Status: Clean
X-CMAE-Envelope: MS4xfC6/Ycu1YlwTT/r9gKdgqhPZQ+/BrYmNRNh7WL9yb5Q7+32UUvGdL/YXgOvmLFWEnusdGLRZkrf4hdUJyHmED8MTSbBNWHS0kgVGQfIKohtmUtehamuh
zvuwQmy8QHG2WUbS0CpKG07i2RuQpp5/EWxmCtb5jgqLsFeEUX+NoOQeGppP7VOuvfyMfbHAvuwedodcR5nKbEGm6OhEOZ9RtQs=
There seems to be very little progress on a resolution, is gmail blacklisting plusnet/freenetname?
Fixes: 526
@C-P Weirdly, only on mobile client - not on desktop, even though the server settings are the same.
but is the sending email address (identity) the same on the mobile as on the desktop ?
@martinrb are you using your own domain as the from: email address ?
if so where is that domain hosted and does it have an SPF record which allows sending via the PlusNet relay ?
