Greenby webmail extremely slow
simonc2
Has anyone else found the webmail.greenby.com site extremely slow to respond this morning (Thu 5 Feb 2026)?
It gets there in the end but displaying a message takes 20-30 seconds.
46 REPLIES 46
jamiekets
Re: Greenby webmail extremely slow
I am unable to logon to webmail at all as my password is not being accepted even though I haven't changed it.
I also have various devices configured to connect to my Plusnet IMAP mailbox and they are failing as well.
This seems to be a regular occurrence since the migration to Greenby
stephenparker
Same here
Can't log on to either Plusnet Webmail or Greenby
delacoe
Same here, not at all happy with plusnet since they migrated!
racal
Mine is inaccessible at the moment - in Webmail it times out saying "Login failed, please check your credentials".
It did this once or twice yesterday but seems to have failed completely this morning.
teamdb
Same here, ai-crapbot suggested changing password, did, still failed so ticket logged...
Fixes: 382
One day, Plusnet/BT and Enix/Greenby will acknowledge that the product is not fit for purpose - but don't hold your breath.
Innovations
Has anybody said when this will be fixed?
K_H
Same problem here - email clients on several devices fail to conenct, and webmail from within the Greenby dashboard thingy fails to connect saying credentials are wrong.  I have 2 Plusnet accounts and both are affected across all the mailboxes within them.  Changing password has no effect.
u123072
I'm unable to log in to mail via either webmail or using Thunderbird.
Various errors including: no access at all, imap errors, squirrel mail errors
Not happy
paulmacd
I cannot log in either, haven't had many problems previously. metronet.
redsox9
Fixes: 4
Looks like the Greenby server went on  a tea break. "Receiving' reported error (0x800CCC0F) : 'The connection to the server was interrupted. If this problem continues, contact your server administrator or Internet service provider (ISP).'
teamdb
"Hi David
This issue is currently under investigation and will be resolved as soon as possible.
Thank you for your patience.
Please feel free to reply to this ticket if you have any additional details to share.
Best regards,
Sajith,"
simonc2
Well, I suppose we should be grateful that Greenby have at least recognised there is a problem...
davidheaf
I too cannot connect to plus.com with my email client (OE CLassic) or webmail.
