Greenby - unreliable login?
johnnorris-10
This actually regards my neighbour (honest!) who is also a plusnet customer and was migrated to greenby.
The problems started because he did not know his password (it was in the email client so could get email) and his plusnet admin email was way out of date. This meant that any notifications about email migration to greenby went to a non existant mailbox so was never read.
The migration happened several weeks ago so greenby had the username, the unknown password so logging into webail was impossible. With the help of plusnet support, we were able to set a new password for both greenby admin and greenby email (yes they are separate) but here is the problem.
We have never managed to log into webmail despite setting an email password. The email password does work for the email client and so dow downloads happen. With greenby.com sometimes we can login and sometimes not.
As greenby spam filtering is so poor, being able to login to webmail is essential in order to review the junk folder.
Why is greenby so unreliable when it comes to logging into their sites?
26 REPLIES 26
PhilipHeyes
Aspiring Champion
Fixes: 18
Re: Greenby - unreliable login?
Failing to maintain ISP credentials and keep current email up to date is all too common a problem.
You may not be alone in seeing glitchy email logins, but since migrating the greenby we have not been affected by this gremlin i.e. webmail.greenby.com and MS Outlook + Thunderbird are authenticating reliably for POP3 & IMAP & SMTP.
In the greenby,com portal consider turning the Spam filter OFF, this will ensure all messages remain in the Inbox and can be seen in an email app or email client on a computer without needed to revert to webmail.
johnnorris-10
The problem with switching filtering off is that there is no chance then to tell Greenby that it is not junk / junk and so it won't learn. Sometimes [email protected] accepts emails, other times not.
I do realise that based on what I have seen so far, greenby spam filter does not learn. For instance, I can go into email to find emails from the plusnet community mailer in both inbox and junk.
pvmb
Aspiring Champion
Fixes: 15
My experience is that to log in to Greenby Roundcube webmail I need to use my full PN email address, not PN Username.
But I log in to the Greenby site itself using my PN Username.
WRT Spam, I have not so far seen any sign of any incoming Spam in the short time I have been with Greenby. In fact the current Greenby Spam filter seems to me stricter than the PN one, I have had about three genuine emails directed to the online Spam box - but all that was needed was to flag them as Not Spam and they were moved back to Inbox.
redsox9
Fixes: 4
I found that Greenby does not remember "Not junk" instructions.  You have to create a filter or put the sender on a white list. However, Greenby seems to be dyslexic. I have turned off the spam filter altogether and only get 1 or 2 spam messages as in the pre-migration era.
kenm
I have found that putting anything into the Whitelist or the Blocked Lists
they DO NOT WORK .
I raised a ticket about it and the machine admitted they dont seem to work.
I have just got Full Fibre and it wizzes thru log in etc but soon as i hit the Webmail button everything goes into slow mode
10 to 15 seconds to open an email, same again to put it in trash,
raised a ticket complaining about slowness
after 8 days got a reply that they had checked and everything was fine their end Huh
Old PN Email was a bit off at times but it was 100% better than this lot
Only good thing is dont have to pay for 2 years !!
I only use Greenby   No client or any other programs
Kenm
Fixes: 383
@kenm Everything after login on that platform reminds me of the old 56k dial-up days. I'm glad I only visit once every couple of days to check I haven't missed anything through my client. I shouldn't have, but I'm still not convinced Greenby is reliable.
PhilipHeyes
Aspiring Champion
Fixes: 18
I have two bits of the greenby.com web portal that don't function.
1) In the email management there is 0% shown for all seven mail boxes, from the Plusnet Webmail I am aware one of the mailboxes Inbox has over 100MB & another has about 20MB in the Inbox.
2) The other is the "VIEW WEBMAIL" buttons, clicking one any one of these results in a new tab opening that says :
RC error: Login failed, please check your credentials.
I tried in Edge and Firefox, no joy in either.
Fixes: 383
@PhilipHeyes
1) I had a problem the opposite way with the mail management tab - because I have it to delete from server on download, there should be nothing there when I have downloaded the messages, but one of the accounts showed 14.3kb (1 email) for about an hour after it was downloaded, read and deleted.
2) Not had that, and I only migrated recently, as you should be aware.
pvmb
Aspiring Champion
Fixes: 15
1) Don't know if it helps but logging on via Greenby portal and selecting Email gives:
Email
All Mailboxes
<full email address> 0% Used - 318MB of Unlimited
Email Domains
<username>.plus.com 15.5% Used - 318MB of 2GB
So the usage dial in the Roundcube UI seems to correspond more to the former, not the latter.
2) Where are these "VIEW WEBMAIL" buttons? I can't seem to recognise them from my Greenby account.
PhilipHeyes
Aspiring Champion
Fixes: 18
Login to greenby.com
Upper left click on Email
I now have a list of our 7 email accounts and on the right hand side of the list is "VIEW WEBMAIL"
one button for each account.
I opened a support ticket on this, but I rejected the suggestion to Reset the Passwords
on all 7 email accounts.  Not a chance when all mail boxes working well on our laptops and mobiles.
pvmb
Aspiring Champion
Fixes: 15
...What can I say? I logged on to the Greenby portal, went to Email, saw the View Webmail button and clicked on it. After a bit (!) I was at my usual Roundcube email page. Seems to work OK for me - though I only have one email account to deal with, not seven! Which one of those accounts has the same login credentials as used to login to the Greenby portal? In my case there is one and only one for both circumstances - so no confusion is possible.
But usually I simply log on directly to Roundcube at webmail.greenby.com rather than via the portal.
mavison
If you sign in to Greenby.com, then select the email tab, you will see a list of your mailboxes, then your email domains (probably one).
The domain line will show the % usage and slider for the domain (ie all your mailboxes) as a % of 2GB (the overall limit).
The mailbox lines may show 0% usage of Unlimted, because you have not yet set a limit for that mailbox. To do that click on the three dota at the right, select Edit Stoirage Space, Then click on Unlimited Storage Space to turn it off, and set the maximum storage space for that mailbox. Note that you can set it to more than the overall limit for the domain, which is silly! If you set them all to 1MB you will see the % become useful. Having different limits for each mailbox may be useful, but means the % are of different amounts which may be confusing.
Sorry, cannot help there, as it works for me in Firefox. I can understand why you are reluctant to change passwords, but If it really is persistant, you could try changing one mailbox password to be the same as it is currently and see if that fixes things. I have seen comments that some special characters (maybe "%"?) was acceptable to PN but not to Greenby, but my memory is hazy about that.
mavison
If you logon to greenby.com, then either select Manage against your email product, or select the Email option in the main menu. You should see a View Mailbox button on the right for each mailbox listed.
PhilipHeyes
Aspiring Champion
Fixes: 18
Using greenby.com portal I tried the change password twice with one of my email accounts and it failed to work
The Generated password was not applied, the original password was displayed again.
I get the impression for a <domain>.plus.com a/c even if you can change the password only the inbox password is changed
as the SMTP server relay.plus.net still belongs to Plusnet.
