Greenby email catch all setting?
Fixes: 582
Re: Greenby email catch all setting?
In theory yes. They would need to use different selectors and DKIM records for the Greenby keys and keys/selectors would need adding to the Plusnet DNS.
I suspect that the problem is that the Greenby system is setup to generate DKIM keys at the account (subdomain in this case)  level and that would mean DKIM key records being added to every subdomain!
njay
If so, then another gotcha as whilst the official outgoing server is plusnet relay server which presumably does pass dkim not everyone can use that
Also, trying to understand dmarc=pass result in earlier post.
PhilipHeyes
Champion
Fixes: 19
dmarc=pass occurs if either spf=pass or dkim=pass are present.
pvmb
Champion
Fixes: 15
Oh dear! This sounds as if it may perhaps be a possible issue that occurred to me a while ago: The nature of Plusnet's email address system, based as it is on a sub domain name containing the username, means there are as many Plusnet email 'domains' as there are email users. (Hope I'm wrong).
njay
I can see in the header in post 10
header.from has spf=none and smtp.mailfrom spf=pass
So does dmarc only use the latter and why did one pass and the other result in none as assume in this example both are the same email address?
PhilipHeyes
Champion
Fixes: 19
@njay
spf=none smtp.helo=ashley.gateway.enmail.co
This means the Greenby host ashley.gateway.enmail.co does not have an SPF entry & that is correct.
njay
How does spf=pass then if outgoing mail server isnt valid for spf?
PhilipHeyes
Champion
Fixes: 19
