Greenby Migration Timetable?
jimchjones
Is there any news on when the greenby migration will be complete? And is there a guaranteed way to check whether one has been migrated? I don't have a great deal of confidence in "Try-and-login-to-Greenby-and-see-if-it-works" as a method of checking migration status.
Its starting to get a bit adjacent to end of copper, but I can't move to BT fibre until my legacy email has been migrated. I also don't have a lot of confidence in communications, asI just discovered my mother's email is migrated to Greenby, in spite of no message saying migration complete.
6 REPLIES 6
Fixes: 587
Re: Greenby Migration Timetable?
Why not ? The Greenby account is only created at the point of migration. So if you can login using your existing Plusnet credentials, you've been migrated!
jimchjones
The other situation however , if you can't login how do you distinguish  between notmigrated and credential error?
Fixes: 392
@jimchjones What error do you get if you try to login here:https://greenby.com/ , with your PN username and account password?
Fixes: 587
@jimchjones
Ok , there is another way if you are familiar with email headers.
If your account has been migrated, then incoming mail is delivered by the Greenby servers and will contain a header of the form :-
Delivered-To: <your email address>
if it hasnt migrated then it will still be delivered by the Plusnet servers and will contain a header of the form ;-
Envelope-to: <your email address>
jimchjones
Thanks, took a look at the mail headers, but still not completely confident of status.
plusnettony
Fixes: 81
If your username linked on the portal is correct, you haven't.
You'll get an email from Greenby when it goes through.
 Tony T
