Gmail Force9
stepea001
Gmail Force9
Trying to setup a force9 account on gmail on a new mobile phone - I can send messages from this account but none incoming. Message displayed "Problem syncing".
Do I need to change anything on the incoming settings.
4 REPLIES 4
Fixes: 254
Re: Gmail Force9
Depends what they are presently set to.
IMAP or POP3?
Is there anything indicating that there is a successful sign-in?
Does the email client facilitate changing the server time out?  Try setting that to 2 minutes.
stepea001
Re: Gmail Force9
Currently set to imap
Incoming Settings
Server: mail.force9.net
Port: 993
Outgoing Settings
Server: relay.force9.net
Port: 587
Re: Gmail Force9
If you are using imap it should be
Incoming Settings
Server: imap.force9.net
Port: 993
mail.force9.net is POP3
@Townman  has previousy published these settings.
IMAP: imap.plus.net port 993 encryption SSL/TLS
POP3: mail.plus.net port 995 encryption SSL/TLS
SMTP: relay.plus.net port 587 encryption STARTTLS
User name (authentication) configured on BOTH incoming and outgoing servers
Default mailbox accountname
Secondary mailbox accountname+mailboxname
Some long term customers will need to change '.plus.net' to '.force9.net' or '.free-online.net' for both your incoming and outgoing servers to match your account
HTH
stepea001
Re: Gmail Force9
Thanks that helped
