Forwarding woes
- Re: Forwarding woes
Forwarding woes
27-09-2026 11:36 AM
I had the email to say migration would start 6 September but I've not heard anything else. I was surprised that my emails had dried up completely but it was only then that I found the redirect option with PN email is broken. I had my individual mailboxes set up as redirects. I've now changed them to alias so all the mail goes into the main email account I can see that over the the months I must have missed a lot of marketing emails that got dumped in the redirect process which is annoying.
I tried forwarding the mail thats now showing up to my outlook but that failed ( I see there's another thread about that) which is also annoying.
When I added the PN email account to my email client it defaulted to the mail.enmail.co imap server and I am collecting mail successfully with that setting but I thought I stayed on imap.mail.net server until I migrated to Greenby? I can't log in to Greenby as my account is not found which confirms I haven't been migrated.
Can anyone clarify. I'm so glad I decided not to rely on PN Email a few years back when the writing was on the wall that there was little interest in making it reliable. Overall this migration looks like a mess to me.
Re: Forwarding woes
27-09-2026 12:21 PM - edited 27-09-2026 12:33 PM
Plusnet forwarding lacked ARC RFC 8617 hence it became increasingly broken after about 2020
when the emails started being rejected by the major email operators for failing SPF i.e. for looking forged.
Greenby's forwarding process does have ARC & does work.
Seeing an email client's wizard pick mail.enmail.co means your DNS MX Records have changed to mx.enmail.co in readiness for the the migration to Greenby,
Greenby's email server mail.enmail.co offers : POP3 / IMAP / SMTP with SSL/TLS & STARTTLS on the standard ports.
If you are using a recent version of Windows / MS Outlook and your choice of settings do not stick,
close MS Outlook and apply the email settings via the Windows Control Panel.
Re: Forwarding woes
27-09-2026 12:49 PM
The login to www.greenby.com will be the same credentials as are used for the Plusnet Member's Centre.
Re: Forwarding woes
27-09-2026 12:58 PM
Re: Forwarding woes
27-09-2026 1:04 PM - edited 27-09-2026 1:19 PM
@the_groundsman wrote:
... I've got a while to run in my contract but if things stay the same, I'll need to move.
Are you aware that a surprising number of ISPs and AltNet FTTP networks, will offer to pay off your current ISP's exit fees (and you ask), as a sweetener for new customers to switch providers.
Take a look at providers that would consider moving to, and read their small print regarding this, as you might be able to move sooner than you think. !
Re: Forwarding woes
27-09-2026 1:17 PM - edited 27-09-2026 1:29 PM
My preference is for all ISP services un-bundled, price is less important than flexibility & having control.
Just look at the torment that has been caused this year with the retirement of the Plusnet email and the end of Analogue phones occurring in the same time window ... all stuck in a bundle Plusnet refused to break up.
Not wanting to loose long used Plusnet email account during a slow phased migration to Greenby has preventing folks from making other ISP or Phone arrangements.
Not being able to Port the landline number without collapsing the entire bundle has left others totally frozen with no clue what to do and the end of Jan 2027 soon to be under four months away.
Re: Forwarding woes
27-09-2026 1:40 PM
@PhilipHeyes wrote:
... the end of Jan 2027 soon to be under four months away.
That is only 86 working weekdays from now.
There are approximately 1.5M PSTN connections remaining to convert to VoIP, so that's 17442 per day. Good luck with that !
Re: Forwarding woes
27-09-2026 1:55 PM
Openreach confirm post-January 2027 measures for UK analogue phone switch-off UPDATE
"Network access provider Openreach (BT) has today outlined the next stage of their closure preparation for the old Public Switched Telephone Network (PSTN), which helps to confirm the plan and service pricing that will occur for consumers that fail to migrate to a modern IP-based digital line alternative by the early 2027 closure deadline."
