Email folder(s) contents emptied!
jamesfrombolton
Hi - posting this on behalf of my Grandparents who use plusnet webmail for their emails (and being 26, I am their unofficial IT support!). I'll get to the point - they have used plusnet webmail for 12+ years and have always sorted their emails into folders, and deleted ones that are unimportant or don't need keeping (including emails from myself!). All of these folders as of today (perhaps earlier but today is when they noticed) have been completely wiped of all contents. I can't believe that they had any storage issues given how much they clear out extraneous emails and only keep important ones. Have looked around the forum and saw it suggested to make sure the user is subscribed to their folders (not sure I'm using the correct language here), we did that and it unveiled some folders that had been hidden, but did not recover any of the deleted emails (in fact, the hidden folders are also empty). I am completely stumped by this and have told them their best bet is contacting Plusnet in the hope that because this is seemingly an error on their end they can go some way to recovering the lost emails. Was hoping someone in the community might have had any luck with anything of this sort or even any idea as to what might have gone on?
I should add, their inbox has not been wiped - the issue is exclusive to all folders apart from the inbox.
Thank you for reading and thanks in advance for any help/advice/info you might have!
James
30 REPLIES 30
mobius01
Re: Email folder(s) contents emptied!
Hi James.
Not much help but I send the following. Like you I am not particularly IT literate.
Same thing happened to me two days ago. E Mail inbox ok but draft and sent folders emptied. Other folders disappeared but I got them back. Not much use. They were empty too. Plusnet no help.
I have been with Plusnet for many years (forgotten how many). They used to be brilliant. Not now. Broadband keeps dropping out. EMail now useless since the migration to Greenby.
Fortunately my broadband contract expires in two weeks. I am moving. Anything is better than this.
Good luck.
Ian G
Penny
Fixes: 9
@jamesfrombolton  @mobius01   There have been other, recent issues of e-mails and/or folders disappearing (now fixed or solved) so I've escalated this thread in the hope that @plusnettony (who has helped other PN customers with such issues but also liaises with greenby) might be able to help.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Fixes: 244
I’ve had reservations about migrated folders for a while but not had the bandwidth / controlled opportunity to investigate.  Are the folders empty or not present. There are two considerations …
  1. Folder subscription status
  2. Folder location in the file store
Folder subscriptions are a function of the IMAP server.  It is unclear if the subscription status is transferred by the migration process.  Check the folder subscription status in webmail or the preferred client.
Depending on the nature of the mail server, folders can be located in the inbox folder or at the same level as the inbox folder.  It might be necessary to change the IMAP root folder in the client settings.
The IMAP server connection diagnostic (see below) will list the folder structure independently of the behaviour of an email client.
Let me know if you want help with that.
plusnettony
Fixes: 68
@jamesfrombolton - I can try and escalate this and find out what's gone wrong. Can you let me know their email address please? PM me the details. Do you know if they'd had communications about Greenby transfer?
@mobius01  I've found your username ok. Do you want your case escalating? The reason our front line cant help directly is because you're no longer with us for email, but we'll still do what we can to assist. If you want us to look at the drops rather than leave, please let us know (faults.plus.net or raise another post in the relevant section of the forums) and we'll advise.
 Tony T
mickrachel28
Hello,
wondering if you can help, my folders on email are also empty which is annoying as some contain documents do you know how to get them back
many thanks
Rachel & Mick
mobius01
Hi everyone.
Further developments.
I logged on to my account this evening and the contents of the 'sent' and 'draft' folders, which disappeared earlier in the week, had reappeared. How/why? Don't know. I have not changed any settings that I know of. The only different thing I did was to log on first using an old laptop (which is not used much because it does not have up to date virus protection) and check the E Mail account that way and the files were there. I then logged on with the current laptop and the files were still there. I hope that they remain!
Best of luck to those of you who have lost files. I hope that they are found as easily as mine were.
Many thanks to those of you who offered to help even though I did not use it.
Stay safe.
Ian G.
plusnettony
Fixes: 68
Glad it's back, do you use imap?
 Tony T
plusnettony
Fixes: 68
How are you collecting email normally? Does it appear like normal in webmail?
 Tony T
mickrachel28
Hi, I have been in touch with Greenby this morning who we’re going to pass it on to the technical team and they have all returned now thank goodness, I will now download my documents to files in case it happens again
many thanks anyway
mick & rachel
mobius01
Don't know (if I use imap). Not IT literate.
plusnettony
Fixes: 68
Have you tried webmail.plus.net, if not, please try as I'd like to see if you see the same issue there.
 Tony T
mickrachel28
All folders now restored with emails
catus
my folders and emails have all gone  without any notification, how can i get them back
Rach_H
Hi @catus,
Welcome to the Community!
I'm sorry to hear about what has happened with your emails, and I can understand your concern. I've raised this with our team, and I will let you know when I hear back from them.
Rach
