current SPF record
SteveA
current SPF record
I currently have the following set tor my domain (dns is via netnerd) v=spf1 +mx +a +ip4:185.229.21.108 +ip4:185.229.22.122 +ip4:81.27.85.25 +include:_spf-internal.plus.net +include:_spf-internal2.plus.net +include:madasafish.com -all However a check shows that several of the IP addresses in the _spf-internal2.plus.net set are duplicated in _spf-internal.madasafish.com Are the changes to PNs email services being reflected in the SPF record?
2 REPLIES 2
Fixes: 253
Re: current SPF record
That is to be expected, plus.net and maaf.com both use the same address spaces.
Why are you referencing both plus.net and maaf.com SPF lookups?
On a quick scan the only duplication I saw is in relation to 84.93.230.227 (specified in the plus.net group) with 84.93.230.224/27 (in the MAAF group).  See also https://community.plus.net/t5/Email/Correct-SPF-record/m-p/1905900#M41782
What issue are you encountering?
SteveA
because that's the spf set that PN said to use - somewhere on this forum back in the mists of time
So it could well be wrong now, and with Greenby getting involved I thought I should get it set correctly for my domain
