Email Not Appearing On Outlook?
Brand0n
Hi all,
I currently have a customers computer on the test bench and they are using IMAP emails with the plus.com domain.
Something really weird is going on where when adding their emails to a new profile on outlook, it says "synchronising inbox" at the bottom of outlook but nothing appears. I have turned off the filter and still nothing!
I have noticed a few emails come through in the "Trash" and "Drafts" folders but apart from that there is nothing!
The IMAP settings I have used are:
Server - imap.plus.net
SSL/TLLS
993
SMTP Server - relay.plus.com
STARTTLS
587
Am I missing something? Or is there an internal issue with the IMAP servers?
Thanks Smiley
9 REPLIES 9
Fixes: 251
Re: Email Not Appearing On Outlook?
You might find that setting the IMAP root folder to inbox might resolve the issue.
Gel
Champion
Fixes: 29
Brand0n
Thanks for this!
I have tried this but still no joy Sad
They have more then one email account hosted by PlusNet and all of them aren't working.
I have also tried adding the emails onto Microsoft mail and still does the exact same thing
Brand0n
Update:
I have set the emails up as pop and the emails cam through straight away, however now the subfolders arent appearing. Any suggestions?
Fixes: 251
Go back to IMAP as POP3 is not fit for purpose - it only looks at the inbox.
Try setting the server timeout to 2 minutes. Are there any emails with large attachments?
Brand0n
I have done this and still no luck Sad
There is a error under the Synchronization Log, the error is 800CCDE-0-0-560
Fixes: 251
Given that there is a specific error code, then look to problems with Outlook rather than the email server.  Google delivers lots of reference to this error code and a good deal of suggestions - for example see Methods to Fix IMAP Synchronizing Folder Error 800ccc0e-0-0-560 in Outlook (datarepairtools.com)
You might also try running Outlook in safe mode - with Outlook shout down, press the Window_Key+R then in the box type
outlook.exe /safe
Brand0n
I originally thought Outlook was the issue however I have even tried adding the accounts onto just the mail app and is doing the exact same thing
Fixes: 251
Windows Mail is a very cut down version of Outlook, so the fact that exhibit the same issue is not surprising.
As per previous advice / question (as mentioned in the linked to suggested fixes) is there a large mail item, in any of the IMAP folders?  Given the POP3 downloaded quickly, I would look at the sent items folder.
Can you access the mailbox via webmail to check item sizes.
Raise the server timeout to 5 minutes and just leave the mailbox to see if it syncs.
