EM Client
yfront
EM Client
Trying to configure EM Client using imap.
Diagnostics show a green successful tick for both imap & smtp when using my Plusnet default email account using USER as the login name, an email account I don't use.
However I'm unable to log in using USER+name getting only a green tick for smtp, I know the password is OK for this account as I can log in OK using webmail (at least sometimes). 😉
It seems as if EM client is unable to cope with the + being part of the USER log in.
Hope this makes sense.
Thanks for any forthcoming help.
Fred
3 REPLIES 3
Fixes: 251
Re: EM Client
Hi Fred,
Does the EM client attempt configure the server names it self?
It would seem odd that you can access relay.plus.net with USER+name (remember that user names are all lower case) but not imap.plus.net
You could try [email protected] as the logon ID.
To recap...
  • Inbound server
    • imap.plus.net
    • Port 993
    • Encryption TLS/SSL
  • Outbound server
    • relay.plus.net
    • Port 587
    • Encryption STARTTLS
    • Authentication required - same as inbound
Fixes: 251
Re: EM Client
Thanks to @MisterW  ...
That should read ...
You could try [email protected].com as the logon ID.
Embarrassed
yfront
Re: EM Client
Thanks for the response.
I'll continue try log in combinations and report back if I have any success.
