Duplicate email (Plusnet MX issue?)
starfry
Re: Duplicate email (Plusnet MX issue?)
@bobpullen re the accounts:
* the forwarder with the issue is a username+mailbox mailbox, the other forwarder on the same domain is the top level username mailbox.
* the other one I referred to (not on 20i) has one forwarder to icloud (apple) and one to a username+mailbox mailbox.
(username in all examples above being my PN account).
I can DM the specifics to you if you want.
starfry
@bobpullen I spoke with 20i today
"In the logs we can see "Remote host closed connection in response to end of data" - this is the important part. The email being sent by the same forward relay server multiple times because of that message. This error indicates it was successful in reaching them but you are disconnecting us. After this, the message is re queued to try again and will keep trying until they return a 250 code which is a successful message with no issues. We can't do anything this side as you are disconnecting us"
Fixes: 251
Bob is away for a couple of weeks, so he might not respond quickly.
semitone440
I'm also receiving triplicate emails from one specific sender, corresponding to the same pattern of two together with a third following later. The sender's domain is hosted by Namesco and, having checked their logs, their support team reports that "even though the receiving server at mx.core.plus.net told us it failed it actually completed tricking our server to send it again".
I also have spam filtering disabled and my own domain hosted by Plusnet.
To test the theory that email redirection might be involved, I asked the sender to address emails to my default [email protected], which would presumably take my domain and any email redirection out of the loop. However, it has made no difference as the triplicate emails still keep arriving.
Fixes: 251
Is the sender also with Namesco?
semitone440
The sender's email headers show that they are sent from smtp.hosts.co.uk which I gather is part of Namesco.
Fixes: 251
So potentially the exact same issue - sender's side?
semitone440
Not as far as I know. Just to clarify, the sender is with Namesco and I'm with Plusnet and it's only emails from him to me that are affected. He reported the problem to Namesco and forwarded their reply on to me.
