Deleting emails
pippup143
Deleting emails
Hello.
On my iPad and phone the additional mailbox I set up has little boxes by each email so I can delete a few at once. But on the main mailbox there aren’t any. I’ve looked through the help topics and can’t find a setting for it. Any ideas. Thanks
4 REPLIES 4
Fixes: 1,663
Re: Deleting emails
Hi @pippup143
I'm sorry to see you're having issues deleting your e-mails in bulk from your default mailbox.
If you've set this up on your iPhone & iPad in the same way as the additional mailboxes, it should behave in the same way.
Can you take a screenshot of what you're seeing and post it up? Just remember to remove any personal information from the screenshot, or feel free to send me a private message if it's easier.
Fixes: 251
Re: Deleting emails
Which version of iOS?
Note that the selection radio buttons appear only when you click on EDIT in the top right corner.
pippup143
Re: Deleting emails
Thanks for your reply and my apologies for the delay in responding.
I’ve found, quite by accident clicking on the wrong spot, that there’s a tiny button on the left on the top menu that opens a window to select things like this!
Thanks again
pippup143
Re: Deleting emails
Thank you for your reply and my apologies for the delay.
I’ve found the answer quite by chance…see reply to message below.
Thanks again
