Compensation from Plusnet for email outage?!
Fixes: 387
Re: Compensation from Plusnet for email outage?!
@briston You can use an email client with PN - I did for the 9+ years I was with them , and still do.
briston
@Batphone strange. I'm set up on port 993 incoming and 465 outgoing with security set.
briston
@jab1Maybe something has been lost in the translation. I do use an email client and my own domain name. Apologies if I have misled someone
Fixes: 387
Sorry, @briston . Re-reading, I see you were recommending the use of a proper client over webmail - apologies.
briston
@jab1 np
wakeman
Fixes: 4
PlusNet do have secure email available, been using it for months now.
POP uses 995 SSL
SMTP uses 587 STARTTLS
Rik13
@jab1
Yes you can , but (until recently according to one of the above posters) they did not use a secure connection to connect to it.
Fixes: 387
@Rik13 - don't quite understand your last comment. Secure mail has been available for 6 months +. Not sure when it was released, as I don't worry about it, but my 6 months could be a very conservative estimate.
Rik13
@jab1
Mine was set up in Thunderbird a long time ago and the settings were , and still are ... security type none , and password transmitted insecurely , they didn't support secure password and there was always concern about it . Apparently this situation has changed.? Not that it matters to me I don't really use it and only check it occasionally through webmail .
Fixes: 387
You could change that - if you wished -now. The current set up details don't mention the 'insecure' settings at all, AFAIK.
Rik13
@jab1
I'll try it out when it gets back up and running.
MFredericks
It's a free service offered which has no guarantees - so I assume you are not entitled to any compensation...
MFredericks
It's not a service provided as part of your T's and C's
RoryG
It is not a free service, it is advertised as part of their business packages.
Fixes: 387
@RoryG but not charged as a separate component of the package?
