Cannot send to gmail addresses
Fixes: 585
Re: Cannot send to gmail addresses
@aimless101  you have a space in 'please-add -spf-records' between the add and the -spf , remove it and try again.
You can check if your domain has an spf record by going to https://mxtoolbox.com/ , enter your domain and click the MX lookup button. When it gets the results , use the dropdown arrow now there on the button, select SPF record lookup and click. That should return the SPF recrod if you have one.
Note it can take up to 6 hrs from adding the MX 999999 record
aimless101
Aw thanks for getting back so quick
no spaces in the actual record
here is the spf record gobbledygook to me I'm afraid
im testing sending mail as googlemail to see if that works!!
cheers
Fixes: 585
@aimless101 that's not the SPF record , its the MX record, click the 'spf lookup' link and post the results of that
aimless101
right just shows what a numpty I am - here it is which as there is no records suggests why im having a problem - legacy from madasafish perhaps  😁
Fixes: 251
@aimless101 wrote:
don't understand all this tech gobbledy [-Censored-]
have managed to put in mx 999999 please-add -spf-records but it has made no difference
its getting frustrating not being able to forward or send to gmail accounts
Can you help me simply in real layman's terms
Thanks in advance
It is not gobbledy anything - its standard technical configuration and like it or not, you are playing with technology which you do need to have some knowledge of.
Please check that the entry looks exactly like this...
For the avoidance of doubt leave the left side blank, exactly as shown. It might take Plusnet's systems up to 6 hours to generate the SPF record.
No abbreviations, no addition spaces within or at the end of the Type or right field.
Did you wait six hours before attempting to send again or check MX tools.
Sending to [email protected] rather than [email protected] or send from [email protected] is not likely to encounter Gmail's stumbling blocks for their free users.  Gmail is the problem here, arising for their imposition of optional rule sets, which do not apply to paid for users.  Oddly they do not apply the same rules to delivery to the same mailbox via the googlemail form of the address.  Figure that one out!
49Howarth
I'm also having problems sending sending emails to some gmail addresses. (see attached PDF)
I'm using Outlook 2016 for emails and have seen the 'fix' on this forum, but it's too complex for my basic IT knowledge.
Any solutions or options welcome !
Fixes: 585
@49Howarth from that attachment, it doesnt look like you are sending email via the Plusnet server (relay.plus.net).
What do you have set as the outgoing (SMTP) server in you email client ?
Fixes: 251
@MisterW
550-5.7.26 SPF [arh228.plus.com] with ip: [173.231.241.25] = did not pass
Apparently se6d-iad1.servconfig.com
PS C:\Users\kevin> ping -a 173.231.241.25
Pinging se6d-iad1.servconfig.com [173.231.241.25] with 32 bytes of data:
Reply from 173.231.241.25: bytes=32 time=93ms TTL=53
Reply from 173.231.241.25: bytes=32 time=91ms TTL=53
Reply from 173.231.241.25: bytes=32 time=92ms TTL=53
And therefore nothing to do with Plusnet's email servers / configuration.
@49Howarth sees the usual 'solutions' as "too complicated" ... yet their email client seems to have a complicated configuration, in using a third party SMTP server.
All *.plus.com email addresses (when sent via relay.plus.net) have DKIM configured ... which would not cause the reported issue from Gmail.
Fixes: 585
Exactly! hence my question as to what @49Howarth has configured as the outgoing server
49Howarth
Fixes: 585
@49Howarth Strange, because the IP address reported in your attachment is not a Plusnet mail server. If your mail is going out via the Plusnet server then it will automatically be DKIM signed
I suggest you try changing your outgoing server settings to use port 587 and encryption method STARTTLS
You might also check the box 'my outgoing (SMTP) server requires authentication' and use the same username/password that you use for the incoming server.
Let us know if that makes a difference
49Howarth
Many thanks Mister W,
Those changes you suggested appear to have fixed the problem.
Fixes: 585
Whilst I'm glad that seems to have fixed it, I still don't understand where the IP 173.231.241.25 is coming from in the gmail bounce
pjmarsh
Fixes: 24
Was the email address that the email was sent to a gmail address, or has there been some poor forwarding happening?  The email bounce is coming from [email protected].
I wonder if you've sent the email to some address hosted on servconfig.com which has forward it to a gmail address.  Gmail has then rejected it as the forwarding has screwed up the headers, which servconfig.com has reported on.
Fixes: 251
@pjmarsh
Good call. If there is an intermediate service forwarding mail without RSR then SPF validation will fail.
All other things being equal, unauthenticated access to the SMTP server will not help with the anti spam measures.
