Cannot send to gmail addresses
KevH
Re: Cannot send to gmail addresses
Thanks again for your patience MisterW!
I've updated my txt record and the protonmail domain authentication is now working showing the DNS record has updated. emails to gmail are still failing. Will try again shortly and will update my fasthost ticket.
No change to the rejection code - 550-5.7.26
Fixes: 585
Depending on the ttl value , typically 1 hour , it may take that long before other DNS servers refresh their cache and get the updated record
If Fasthosts have added DKIM  keys to your DNS , you need to remove them, otherwise a receiving server MAY believe your email should be DKIM signed and it won't be.
Fixes: 251
@KevH
If FastHosts is where your domain is hosted, you would find life much simpler using their SMTP servers rather than Plusnet’s. It’s a big ask to expect a third party to carry the responsibility of delivering email for another domain hosting company.
KevH
Fasthosts has resolved my gmail authentication issue. They said there was an error with one of the txt settings. I can't see what change they have made so have asked for confirmation as it may help others  here with the same problem.
I am in the process of moving my email to protonmail as I suspect at my next renewal I may not stay with PN as superfast fibre isn't available to BT group ISPs (City Fibre only). Will be a pity as I've been a PN customer for >25 yrs.
I do pay FH to host my domains and as is often the case with many support organisations it is a matter of luck that you find somebody who can immediately spot the issue - in my case it has taken a dozen interactions with their support team but we got there in the end.
Thanks for all the help and suggestions with my issues. I'm very grateful for the engagement I've had.
Best regards- Kevin
Fixes: 585
@KevH  one thing you can do to check SPF is to send (from your domain email) a test email to your <account>.plus.com email address. Then examine the headers of the received email, that should indicate whether SPF passes and whether DKIM is being used (it wont be)
KevH
The issue was resolved by removing the hostname in the txt configuration as per the attached picture.
I did send an email from my .org.uk domain to my .plus.net account and here's the header (sorry it is long). I can only see a ref to SPF in one of the strings and not sure if this is co-incidence. This level of detail is above my pay grade anyway!
Return-path: <[email protected]>
Envelope-to: [email protected]
Delivery-date: Wed, 14 Feb 2024 09:20:54 +0000
Received: from [212.159.14.25] (helo=avasin-peh-005.plus.net)
                  by inmx-ptp-008.plus.net with esmtp (PlusNet MXCore v2.00) id 1raBRm-000DG6-Ep
                  for [email protected]; Wed, 14 Feb 2024 09:20:54 +0000
Received: from avasout-peh-003.plus.net ([84.93.223.46])
                by Plusnet Cloudmark Gateway with ESMTP
                id aBPrrbZkwpZm8aBRlryGqN; Wed, 14 Feb 2024 09:20:53 +0000
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.4 cv=M4LuKDws c=1 sm=1 tr=0 ts=65cc85f5 cx=a_idp_d
 a=t1A14LVAsJ8csEQeVeuYqg==:117 a=a1lRamv/IdbBpk6QutfALw==:17
 a=k7vzHIieQBIA:10 a=DAwyPP_o2Byb1YXLmDAA:9 a=1FzqG5ILVBdwvA7Y_sMA:9
 a=CjuIK1q_8ugA:10 a=yMhMjlubAAAA:8 a=SSmOFEACAAAA:8 a=gKO2Hq4RSVkA:10
 a=UiCQ7L4-1S4A:10 a=hTZeC7Yk6K0A:10 a=frz4AuCg-hUA:10
 a=TUTuR8WBUdWlqyOwZBeQ:22 a=pHzHmUro8NiASowvMSCR:22 a=nt3jZW36AmriUCFCBwmW:22
Received: from DESKTOPSQO0U6P ([212.56.102.30])
                by smtp with ESMTPA
                id aBRkr9rRT3hmyaBRlrdwiN; Wed, 14 Feb 2024 09:20:53 +0000
X-Clacks-Overhead: "GNU Terry Pratchett"
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.4 cv=AacSHGXG c=1 sm=1 tr=0 ts=65cc85f5
 a=a1lRamv/IdbBpk6QutfALw==:117 a=a1lRamv/IdbBpk6QutfALw==:17
 a=DAwyPP_o2Byb1YXLmDAA:9 a=1FzqG5ILVBdwvA7Y_sMA:9 a=CjuIK1q_8ugA:10
 a=yMhMjlubAAAA:8 a=SSmOFEACAAAA:8 a=gKO2Hq4RSVkA:10 a=UiCQ7L4-1S4A:10
X-AUTH: XXXX@:2500
To: <[email protected]>
Date: Wed, 14 Feb 2024 09:20:52 -0000
Message-ID: <[email protected]>
MIME-Version: 1.0
Content-Type: multipart/alternative;
                boundary="----=_NextPart_000_0062_01DA5F27.1BB1A080"
X-Mailer: Microsoft Outlook 16.0
Thread-Index: AdpfJxWfVULjAo2qRLiS06S5rjNL+Q==
Content-Language: en-gb
X-CMAE-Envelope: MS4xfHsd1c9T7VxgUqiDKGjUmJJAZowLvN2fUoYN8u6sa3hu3M2Cig7z5fd3gbYs3Cj/TsQenRKZosQJwMXqvvPCX0qSPFeEVpp9Ie+XF/flFRaBbBQ+NFOE
 7iZBmckSIWalZSdRItbNf5sARxczpJYYglgKFX3a8WVt6pUSJ7ZD6dC+Wo/CHKPxab+aUvG/DJhegOsbW1DSkrUXtwrvg+HqMIM=
X-pn-pstn-db:" Spam 99
X-PN-Virus-Filtered: by PlusNet MXCore (v5.00)
X-PN-Spam-Filtered: by PlusNet MXCore (v5.00)
Subject: Test
Fixes: 585
Yes, sorry that might have been partially my fault suggesting that the domain should be in the host field, rather than it being blank to relect the native domain. In my defence it was late and it had been a hectic day!
That's a shame , it doesnt seem to report the SPF status , maybe its due to the fact that effectively its an internal email i.e sent and received by the PN servers, so it doesnt bother to check.
I had hoped to see a section after the  'Received by' looking something like
Received SPF - pass (mailhub-hex-d.mythic-beasts.com: domain of bounces.amazon.co.uk designates 54.240.1.4 as permitted sender) client-ip=54.240.1.4; envelope-from=20240213133320f0db17328771470ea181fd012ae0p0eu-C3ORN1CYTBHHQU@bounces.amazon.co.uk; helo=a1-4.smtp-out.eu-west-1.amazonses.com;
AHurley
Hi @Gandalf,
Really hope you can help. I was formally with freenetname.co.uk, then madasafish.co.uk and now plus.net.
I believe therefore my domain is hosted and registered with PlusNet.
I've checked on Mxtoolbox and can confirm I have no SPF record.
can you please help with an MX record so I can send emails to gmail.com accounts?
Many thanks
Fixes: 251
Following the detail of this thread carefully advises that there is no means of creating a SPF record for personal domains hosted on the legacy mail brands.
The two posts in this thread from @Gandalf refer to personal domains hosted on the Plusnet / F9 platform … which is entirely separate.
You have two choices - try to send to @googlemail.com instead of @gnail.com or move your domain name to an alternative email provider.
The use of the native @maaf addresses will work fine.
CW47
I have the same issue with my emails to gmail accounts being bounced with
'Diagnostic-Code: smtp; 550-5.7.26 Your email has been blocked because the sender is unauthenticated.'
I believe this can be resolved by creating an SPF record as below for my domain, which is 1gcc.net
Chris W.
Fixes: 585
@CW47 ?Huh
KevH
For the record, gmail must have made some other changes as my emails from my hosted domain are being rejected once more with the "your email has been blocked because the sender is unauthenticated".
Fixes: 585
@KevH here's google latest requirements https://support.google.com/a/answer/81126?visit_id=638531093909950774-451227997&rd=1#authentication&...
There was a change in Dec 2023 to insist on TLS when submitting the email and then the formalisation of the SPf,DKIM & DMARC requirements in Feb 2024
shapter
Ive just got round to making the dns change suggested on this post and I am now able to send to gmail, my domain is registered and hosted by plusnet.
Thanks for the suggested fix
aimless101
Ive got this problem too! Had it for ages!
I have a domain that is registered with Plusnet
IAna iD Force 9 (whatever that means)
registered with nominet - bought it years ago
don't understand all this tech gobbledy [-Censored-]
have managed to put in mx 999999 please-add -spf-records but it has made no difference
its getting frustrating not being able to forward or send to gmail accounts
Can you help me simply in real layman's terms
Thanks in advance
