Are there problems with the email service?
benjamine1979
I am trying now for 16 hours - but I am unable to either log in to the webmail or download mail to my phone.
When I try to log in, I get the error message "Unknown user or password incorrect." - But I am sure I am entering the right credentials.
For my phone it says, "account error........"
I am currently out of the country, so it is not possible to call the help line - any ideas?
25 REPLIES 25
willcutforth
Fixes: 113
Re: Are there problems with the email service?
Hey there @benjamine1979 I just tried to log into my webmail and was able to so it isn't a server issue. Just for testing purposes have you changed the password and tried logging in?
 Will Cutforth
BrianD1
I've had problems for the last few days. Emails are occasionall getting through but only every couple of days. Can't send or receive emails via Outlook 2019. Been using OL for years, never changed any settings and all emails are received fine on mobile phone. Also cannot get on plusnet website such as https://www.plus.net/ or https://www.plus.net/help/email-guides/how-to-use-webmail/. Can't access plusnet webmail site either. All say 'this site ca't be reached'. Any suggestions welcome! Thank you. Brian
willcutforth
Fixes: 113
@BrianD1 the website has been having a bit of an issue recently that's been flagged up on other posts however that doesn't explain why outlook isn't working. Do you know how much storage you have used up on your mailbox at all?
 Will Cutforth
BrianD1
Thank you for your reply. I can't check how much storage I have as I can't access plusnet webmail site but I haven't had any reminders to look at it from Plusnet which I have in the past. Also wouldn't account for emails working fine on my mobile would it?
willcutforth
Fixes: 113
I'm going to send you a PM because I want to take a look at the account and I just need the username.
 Will Cutforth
BrianD1
Great. Thank you!
BrianD1
@willcutforth should I be looking out for an email from you?
Fixes: 585
You should get an email notifying of the PM from Will. You will then need to go to the link in the email (or to the Private Messages tab at the bottom of each forum page ) , which will take you to the message and enable you to send a reply.
BrianD1
All appears to be working fine today for some reason. Haven't changed anything. Has Plusnet changed something I wonder. Thank you for your help anyway @willcutforth and @MisterW ..
willcutforth
Fixes: 113
Awesome, glad it's working now. If it does go down again. Let me know Smiley
 Will Cutforth
BrianD1
Spoke too soon @willcutforth ! All worked fine until yesterday morning when it stopped working again. No changes made by me so must be on Plusnet's side. Still can't check any plusnet website on Chrome OR Firefox  @ClaudiaG23 . Any suggestions appreciated..
BrianD1
For info..as I can't access any plusnet website to check outlook 2019 email seettings I am using imap.plus.net 993 SSL/TLS relay.plus.net 465 SSL/TLS..I have also tried using Thunderbird which also will not connect to plusnet..
pjmarsh
Fixes: 24
What problem are you having accessing Webmail? https://webmail.plus.net
BrianD1
I can excess webmail but would prefer to use Outlook. For info my wife can receive plusnet emails on Outlook 365 using the excact same setting as I am on Outlook 2019 but I cannot receive/send emails. Does this indicate a OL2019 problem? If so I wonder why it did work OK for a few days, Monday to Wednesday, this week and then goes wrong again..
