very odd unread posts - see picture
Colin
Re: very odd unread posts - see picture
It was only reported on unread posts AFAIK so don't feel too sorry. Angry
pierre_pierre
mine was 100% OK just now, problem cured, (Beat Jelv to that one) Cheesy
Quote from: Colin
Is this now fixed on unread posts *and* updated posts?
jelv
Fixes: 10
I'm only seeing it fail on Replies To Your Posts (it's failed again this morning)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Stickied temporarily to try to reproduce the issue/declare it as fixed.
Could somebody add a reply (Or let me know if this reply caused the problem to re-occur.)
Cliff_Jordan
Seems ok to me now.
Cliff
We aren't concerned about the 'unread topics' one any more - we know thats fixed now Wink
Its the 'Replies to your posts' one thats still to be done.
Also noted that you don't need replies here to test it, it can be reproduced by marking the thread unread, then using the 'Replies to your posts' link to the right of the 'Unread Posts' one.
Colin
It's still an issue, and we know it is.
jelv
Fixes: 10
Is this fixed now? - if so this topic should be un-stickied.
