Width of Subject columns
- Feedback
- Community Site Feedback
- Width of Subject columns
15-02-2009 10:20 AM
Has someone been messing? On some boards the Subject column is now a lot narrower, really irritating - makes it much more difficult to scan throught the titles. Can see any obvious reason!
2 REPLIES 2
Re: Width of Subject columns
15-02-2009 12:21 PM
Is it forums where there are topics either started by "The user previously known as AxisofEvil" or his is the last reply on a topic?
15-02-2009 2:40 PM
Jeremy has now changed his user name back - can you still see the problem? If you can could you say exactly which forum and the screen resolution you are using.
