unread posts
- Feedback
- Community Site Feedback
- unread posts
unread posts
12-05-2016 6:29 PM
is it just me missing something , i have noticed for a while after reading new posts , if i have added a reply when i go back to main fourm page , it shows my post as a new unread post ????![]()
Re: unread posts
12-05-2016 8:28 PM
After you post, do you click on the Blue box that says "Go to my post".
A bit 'clunky' but it gets rid of that annoyance.
M
Re: unread posts
12-05-2016 10:28 PM
No i dont go back anymore after i realized it was my post
at least i know its not just me ..
also sometimes i get a error with the spellchecker ?
Re: unread posts
13-05-2016 8:54 AM - edited 13-05-2016 8:56 AM
@rongtw I think you may have misinterpreted my previous response. Once you've clicked on 'Post' after a few seconds you get a blue banner saying your post has succeeded with "click to go to your post". This updates the position in the thread that you've read up to. Clunky? Yes!
I frequently omit this step myself on busy boards as waiting for the slow page loads takes up valuable time.
On the spellchecking - is it the Americanisms like color that give you problems? If so see this post in Spellchecking
Maurice
Re: unread posts
13-05-2016 9:13 AM
When you reply to a thread you are taken back to the original message you had clicked reply on. If there are multiple pages, your reply will be added to the end of the thread as you would expect but you are not taken to your new reply on that other page. So in this case your reply would be 'unread'.
Re: unread posts
13-05-2016 10:07 AM - edited 13-05-2016 10:07 AM
Ahh i see what you mean now
thanks
Cheers Maurice
Re: unread posts
13-05-2016 6:05 PM - edited 13-05-2016 6:05 PM
@rongtw make sure you have <Show confirmation pages for posts> checked at the bottom of the My Settings : Preferences >Preference Options page then you are prompted to go to your message (if you want).
